LAMotorcycleRider Posted December 3, 2022 Share Posted December 3, 2022 I have a 14 RT I bought a few years back with 1K, I just hit 12K and need to do the first major service. I'd appreciate some tips from anybody with experience who can help. 1. Are there any options to get service parts at a better price than my local stealer? air cleaner, oil filter, gaskets, valve shims, etc. 2. Is there any way to reset the dash service indicator light other than buying a GS-911 or paying the dealer? 3. I have the Haynes paper manual, is this sufficient or is there other service documentation I should get? 4. I'm a tool junky and have almost everything, are there any special tools I will need? Thanks Jeff Link to comment
wbw6cos Posted December 3, 2022 Share Posted December 3, 2022 @Boxflyer has a few posts on this forum answering your questions, 1 - 4, plus many more you have yet to ask. Check out his videos for the 12k service. They also have descriptions that indicate the sources for all his tools and supplies. Yeah, he has a frugal quality about him. https://www.youtube.com/user/Boxflyer11/videos Welcome to the forum, by the way. Cheers, 2 Link to comment
MikeB60 Posted December 3, 2022 Share Posted December 3, 2022 Beemerboneyard is a great place for parts. You can get a 10 percent discount with the code BMWST. There is an android app called MotoScan that you can use to reset the service light. GS911 is another option and has more functions but is more money. Hanes manual will be fine. Definitely check out boxflyers videos you need some special tool to verify cam timing and boxflyer is a great source. 1 Link to comment
MikeB60 Posted December 3, 2022 Share Posted December 3, 2022 Oh yeah one other thing. Make sure to drop the final drive and check the rear splines on you drive shaft. There is a service campaign on the GS with respect to rust but it can be an issue with the RTs as well. Do a forum search for the grease requirements for the boot and splines. Brad may have a video on this subject as well. 1 Link to comment
alegerlotz Posted December 3, 2022 Share Posted December 3, 2022 I second Beemer Boneyard as a source of service parts. I use a GS 911 for resetting the service indicator and other maintenance activities (suspension calibration, brake bleed procedure, etc...). None of this is difficult, its just a matter of being thorough and working methodically. Torque wrenches are your friend and the torque specs for different fasteners can be found pretty easily via an internet search. Link to comment
LAMotorcycleRider Posted December 3, 2022 Author Share Posted December 3, 2022 Thank you everybody for the tips, I like that Boxflyer guy he reminds me of myself. I will definitely check out beemerboneyard. Link to comment
Boxflyer Posted December 3, 2022 Share Posted December 3, 2022 I have several sheets available on my Google Drives page that if you request the link, I can send the document as a PDF. Brad R1200/1250 Tool Kit and Consumables R1200 WetHead Torque Sheet R1250 ShiftHead Torque Sheet Blank R1200/1250 Cam Timing and Valve Clearance Worksheet R1200 Boxflyer Board Left R1200 Boxflyer Board Right 5 Link to comment
Dave_in_TX Posted December 4, 2022 Share Posted December 4, 2022 21 hours ago, LAMotorcycleRider said: I have a 14 RT I bought a few years back with 1K, I just hit 12K and need to do the first major service. I'd appreciate some tips from anybody with experience who can help. 1. Are there any options to get service parts at a better price than my local stealer? air cleaner, oil filter, gaskets, valve shims, etc. 2. Is there any way to reset the dash service indicator light other than buying a GS-911 or paying the dealer? 3. I have the Haynes paper manual, is this sufficient or is there other service documentation I should get? 4. I'm a tool junky and have almost everything, are there any special tools I will need? Thanks Jeff Motoscan is an alternative to a GS911 for resetting service interval. Link to comment
