Chris Moorhouse Posted October 24, 2022 Share Posted October 24, 2022 Hi the warning light goes out when I apply front and rear brakes but won't go off if the lights are on. I changed a dead tail bulb but warning light stays on, can the relay be tested or am I buying a new relay? Cheers Chris Link to comment
dirtrider Posted October 24, 2022 Share Posted October 24, 2022 43 minutes ago, Chris Moorhouse said: Hi the warning light goes out when I apply front and rear brakes but won't go off if the lights are on. I changed a dead tail bulb but warning light stays on, can the relay be tested or am I buying a new relay? Cheers Chris Afternoon Chris It's been years since I have worked on the rear electrical light circuit on the old K75. I don't know (at least I can't tell you anyhow) if there is an easy way to test the BMU (Bulb Monitoring Unit). Back years ago I had a known good BMU I could substitute into the old K bikes as a quick verification test. Does your tail light & brake light properly illuminate? If so are they the correct brightness? (not dim looking?) I do have a old (paper form) wire diagram for the K 75 but it doesn't show the internal circuits that are inside the BMU so I can't even give you a test or check procedure. Link to comment
