rol1 Posted September 15, 2022 Share Posted September 15, 2022 So I guess the three wire of the proper colors are the headlight. And the halogen headlight plugs into that? Looking at the specs it says it is a 55/60 watts load. On the module it says it is rated at 3.5 and 6 amp max. The fuse is a 15 amp? Could I use a. Standard headlight? Got plenty of Chinese scooter parts available. Would I be able to a pair of 35 watt bulbs? Link to comment
dirtrider Posted September 16, 2022 Share Posted September 16, 2022 13 hours ago, rol1 said: So I guess the three wire of the proper colors are the headlight. And the halogen headlight plugs into that? Looking at the specs it says it is a 55/60 watts load. On the module it says it is rated at 3.5 and 6 amp max. The fuse is a 15 amp? Could I use a. Standard headlight? Got plenty of Chinese scooter parts available. Would I be able to a pair of 35 watt bulbs? Morning rol1 You can eliminate that module as it is not a BMW part. You can easily run 1 standard headlight, the basic circuit will probably allow 2 standard headlight's. If your motorcycle has a (European) headlight on-off switch then that will probably be the weak link. 1 Link to comment
