ducati2 Posted September 11, 2022 Share Posted September 11, 2022 I have two heated front seats, one standard height and the other high. One works, the other doesn’t. I know the bike and harness is doing its thing and I don’t suppose bmw sells the heating element separately from their $8-900 seat. So, decided to dive in and I FIXED IT (I hope). It was a matter of removing cover, then first layer of foam, then peeling the “electric blanket” off the main layer of foam. From there I started probing around with an ohm meter until I found the burned/broken element exact spot. Then I carefully soldered a bridge over the trouble area using a short piece of 22 gage solid wire. Tested it for ohms, check, hooked it to bike and checked w my thermal camera, check, then reinstalled it all back together. BEAUTIFUL. WORKS GREAT. Now for a tall beer to celebrate! 2 1 Link to comment
Paul De Posted September 12, 2022 Share Posted September 12, 2022 Nice! And it looks like the beginning of a hobby business for those who would send you their dead saddle without the time, tools, or skills in any combination to fix it Link to comment
christianf Posted December 9, 2022 Share Posted December 9, 2022 Just bought a 2006 r1200rt with a rupture heated wire under the seat. It broke off from the connector when the owner pulled the seat off.. wire was loose, (which I don’t believe is possible but this is another discussion). Now is need to cut off the connector and replace it with another one. There are a few on Amazon that I think I could use that are waterproof but I am wandering if there is consideration with gauge or rating I should look for. Windows would appreciate if you could let me know what you think. Thank you very much Link to comment
ducati2 Posted December 9, 2022 Author Share Posted December 9, 2022 12v and maybe 10 amp might work, but just guessing at what amps the seat pulls. Good luck! Link to comment
lkraus Posted December 9, 2022 Share Posted December 9, 2022 The parts fiche at Max BMW can be helpful since it often has photos of parts (rather than just a sketch) and in some cases the description includes common uses for a part. I did not find a seat connector in the section for electrical repair plugs, but this part might be what you need to keep everything original: Link to comment
