Bill Cats Posted September 6, 2022 Share Posted September 6, 2022 Thank you for all your help in the past . I have watched a couple videos on YouTube on removing the head, so was alerted to Zip tied Cam gear to chain in correct position, - found TDC and locked motor with correct size bolt - NOW it replacement time BUT cant seem to find all the torque specs... what I know --- 20nm and then 180 degree the main cylinder head bolts - 65nm on the cam chain sprocket to cam bolt BUT having much issues finding what i call the ( rocker arm box ) bolts and all the rest.... Any torque spec and order tightening help is deeply appreciated...... Link to comment
dirtrider Posted September 6, 2022 Share Posted September 6, 2022 3 hours ago, Bill Cats said: Thank you for all your help in the past . I have watched a couple videos on YouTube on removing the head, so was alerted to Zip tied Cam gear to chain in correct position, - found TDC and locked motor with correct size bolt - NOW it replacement time BUT cant seem to find all the torque specs... what I know --- 20nm and then 180 degree the main cylinder head bolts - 65nm on the cam chain sprocket to cam bolt BUT having much issues finding what i call the ( rocker arm box ) bolts and all the rest.... Any torque spec and order tightening help is deeply appreciated...... Afternoon Bill Check your messages on this site I sent you a torque spec sheet. Link to comment
Bill Cats Posted September 6, 2022 Author Share Posted September 6, 2022 2 hours ago, dirtrider said: Afternoon Bill Check you messages on this site I sent you a torque spec sheet. Ur the best Sir... Thank u Link to comment
