BeemerBerg Posted August 31, 2022 Share Posted August 31, 2022 My 2005 RT has about 125K on the clock. The ESA shocks never did work right. I found a complete "Standard Shock" on ebay for a decent price. Not sure how many miles are on it--perhaps it's a "take off". Would I have any issues if I just pulled the old ESA and replaced it with this unit? Just leave the wires dangling? Link to comment
dirtrider Posted August 31, 2022 Share Posted August 31, 2022 5 minutes ago, BeemerBerg said: My 2005 RT has about 125K on the clock. The ESA shocks never did work right. I found a complete "Standard Shock" on ebay for a decent price. Not sure how many miles are on it--perhaps it's a "take off". Would I have any issues if I just pulled the old ESA and replaced it with this unit? Just leave the wires dangling? Evening BeemerBerg Good question, you might try to disconnecting your current one to see. It will store a fault code but that shouldn't be an issue, my big worry would be that it will cause the ESA system to default so it then won't allow front damping changes. Link to comment
MikeB60 Posted August 31, 2022 Share Posted August 31, 2022 I've ditched the ESA on three BMWs a 06 RT, 11 RT and my 13 K1600. No issues no lights. Link to comment
Mark Cross Posted September 16, 2022 Share Posted September 16, 2022 Are you changing both shocks to non-esa? I have a take off police pair for $100. Mark Link to comment
Twisties Posted September 17, 2022 Share Posted September 17, 2022 I packed my connectors with dielectric grease and sealed them tight. Zip tied them securely to something or other. You will get some error codes on GS-911, but you will know why and ignore them. Just says the ESA isn't there or some such. Those old, 1st Gen ESA weren't very good. I changed mine out at about 20k miles for aftermarket shocks. Never looked back. Link to comment
