SD1 Posted August 17, 2022 Share Posted August 17, 2022 Ready to start some basic maintenance on the 09' RTP. I am going to do the following, any adds to my list and is there a good single stop shop/site that the forum uses for maintenance and parts? Engine oil Valvoline 20/50 synth Walmart Oil filter Mahle OC306 amazon Air filter 9874/5 amazon Plugs NGK MAR8B-JDS (pretty sure I need 4??) amazon I see most of the stuff on Amazon, but rather buy from an independent The brake fluids look new, but I will be assessing/bleeding brake and clutch fluid and the final drive secondarily. Thanks! Link to comment
9Mary7 Posted August 17, 2022 Share Posted August 17, 2022 A lot of us use Beemer Boneyard.... and someone will chime in with a discount code IIRC.... Link to comment
Rougarou Posted August 17, 2022 Share Posted August 17, 2022 7 hours ago, SD1 said: Ready to start some basic maintenance on the 09' RTP. I am going to do the following, any adds to my list and is there a good single stop shop/site that the forum uses for maintenance and parts? Engine oil Valvoline 20/50 synth Walmart Oil filter Mahle OC306 amazon Air filter 9874/5 amazon Plugs NGK MAR8B-JDS (pretty sure I need 4??) amazon I see most of the stuff on Amazon, but rather buy from an independent The brake fluids look new, but I will be assessing/bleeding brake and clutch fluid and the final drive secondarily. Thanks! I use Rotella T6 5W-40-Walmart Last filter bought was HiFlo HF164-Amazon Last plugs were NGK DCPR8EKC and way, way back, I bought NGK DCPR8EIX-Amazon Brake fluid was flushed 80,000 miles ago. Clutch has never been flushed Link to comment
MikeB60 Posted August 18, 2022 Share Posted August 18, 2022 1 hour ago, 9Mary7 said: A lot of us use Beemer Boneyard Great guys! 10% discount code is bmwst or bmwmoa 1 Link to comment
Dave P Posted August 21, 2022 Share Posted August 21, 2022 SD- I didnt have one of those special oil filter wrenches, so after I did get that "splined" filter off I put a K&N oil filter in that has a big hex nut welded on. Got it at Oreileys. D Link to comment
