joeb Posted August 6, 2022 Share Posted August 6, 2022 Hi all. My 09 GS doesn't have cruise and I'm planning some long trips. Any recommendations for a throttle clamp that fits that bike ? Much appreciated, thanks. Link to comment
dirtrider Posted August 6, 2022 Share Posted August 6, 2022 6 hours ago, joeb said: Hi all. My 09 GS doesn't have cruise and I'm planning some long trips. Any recommendations for a throttle clamp that fits that bike ? Much appreciated, thanks. Morning Joeb That depends on the rider & what THEY personally like. My personal preference is, first a simple "wrist rest" (cramp buster) that takes the fatigue out of continually holding the twist grip tight to maintain throttle position. On the throttle clamp, there are a number of verities on the market. You just have to pick one that you like & will work for YOU. Personally I just use a simple Caterpillar yellow "O" ring that rolls between the outer end weight & the outer end of the twist grip. (simple, doesn't get in the way, doesn't catch on my riding coat cuff, & throttle position is still easily changeable with the "O" ring deployed. Link to comment
joeb Posted August 6, 2022 Author Share Posted August 6, 2022 Thanks, I'll check that out. Link to comment
dirtrider Posted August 6, 2022 Share Posted August 6, 2022 17 minutes ago, joeb said: Thanks, I'll check that out. Morning joeb Here is a picture of what I was referring to above. The "O" ring is a Caterpillar 8M4991 "O" ring, E-Bay usually has them for $4.00 - $5.00 Link to comment
joeb Posted August 6, 2022 Author Share Posted August 6, 2022 Elegant and simple solution. I like. Thank you. Link to comment
szurszewski Posted August 6, 2022 Share Posted August 6, 2022 If the o-ring doesn’t work for you, or you just want to spend a bunch more money, I’ve been happy with an Atlas throttle lock on my ‘12 GSA. Link to comment
