RPG Posted July 27, 2022 Share Posted July 27, 2022 2004 RT w/ 115k. Low Fuel light stopped working. I've checked the bulb (good) but now think it's inside the tank. I believe the float arm activates the switch, so was thinking maybe adding some Techron in hopes of cleaning the contacts? It's not critical as I just stop when the fuel gauge is at zero bars, but would like it to work as everything else on the bike. I suppose I'll need to get inside the tank but was just hoping for another solution before doing that. Thanks, RPG Link to comment
dirtrider Posted July 27, 2022 Share Posted July 27, 2022 17 minutes ago, RPG said: 2004 RT w/ 115k. Low Fuel light stopped working. I've checked the bulb (good) but now think it's inside the tank. I believe the float arm activates the switch, so was thinking maybe adding some Techron in hopes of cleaning the contacts? It's not critical as I just stop when the fuel gauge is at zero bars, but would like it to work as everything else on the bike. I suppose I'll need to get inside the tank but was just hoping for another solution before doing that. Thanks, RPG Afternoon Rick When was the last time that it worked? Have you been into the fuel tank since it worked? Sometimes a mis-routed hose inside tank can prevent the low fuel light float from traveling all the way down. Techron sure won't hurt & might help if your problem is due to varnish. Next time you expose the fuel tank pigtail connector just short the white wire to the brown wire (on the main harness side) then see if the low fuel light comes on, if so then your problem is inside the tank. Link to comment
PAS Posted July 27, 2022 Share Posted July 27, 2022 I have also read that Techron can help with the contacts in the tank. 1 Link to comment
RPG Posted July 27, 2022 Author Share Posted July 27, 2022 3 hours ago, dirtrider said: Afternoon Rick When was the last time that it worked? Have you been into the fuel tank since it worked? Sometimes a mis-routed hose inside tank can prevent the low fuel light float from traveling all the way down. Techron sure won't hurt & might help if your problem is due to varnish. Next time you expose the fuel tank pigtail connector just short the white wire to the brown wire (on the main harness side) then see if the low fuel light comes on, if so then your problem is inside the tank. Afternoon D.R., When was the last time that it worked? The light was working just prior to leaving the the MOA National (June 12th) Have you been into the fuel tank since it worked? Sometimes a mis-routed hose inside tank can prevent the low fuel light float from traveling all the way down. I haven't been inside the tank since two winters ago when I replaced the fuel pump/hoses/filter Next time you expose the fuel tank pigtail connector just short the white wire to the brown wire (on the main harness side) then see if the low fuel light comes on, if so then your problem is inside the tank. That's a great idea. I can do that test before I actually have to go inside the tank. Thanks very much! Link to comment
RPG Posted May 13, 2023 Author Share Posted May 13, 2023 I finally decided to pull the panels and figure this out. Per D.R.'s excellent advice, I shorted out the white to brown wire on the tank connector and the low fuel light illuminated. Which means, the problem is in the tank. Turns out, it was pretty simple. One of the fuel filter clamps had moved slightly AND I used a clamp with extra length screws, which then prevented the low fuel sensor from dropping all the way. I installed new clamps with shorter screws and oriented them in such a way that even if they rotate a little, the low fuel arm won't be restricted in it's movement. If you look close enough at the attachment, you'll see a small scrape on the fuel level arm where the screw was stopping it. Thank You D.R. once again. RPG Link to comment
