Dave P Posted July 26, 2022 Share Posted July 26, 2022 Hello Hexhead folks! I have a new to me 2007 R1200RT with 36k miles. It has a new battery this year. I just changed the oil last night with 20w50 conventional oil. No metal on the drain plug. At a cold start, it starts fine and idles pretty well, except I hear random taps / pops / noises. Noises are not at any regular intervals. From a couple of 1200RT friends I’ve mentioned this to, they say that the hexhead engine just does this. After about a minute or less, the tap sounds generally disappear, but the idle seems inconsistent, not smooth. Kinda bounces around, bike is shaky. Engine still hasn’t been running very long so I guess it’s still kinda cold. My morning commute is about 7 miles, rode it in today. Idles seems pretty good after 7 miles. I wouldn’t call it great, it still is a little bit lumpy, but it’s ok. Looks like it idles at about 1050- 1100 rpm. Seems maybe a tad low to me. Bike at speed seems to run well, has good power. Was planning to evaluate the easy stuff first- air filter, maybe pull the spark plugs, see what they look like. Run a nice fresh tank of premium ($$) gas through her, maybe with some Techron or Berrymans in the gas. I was an airhead RT owner for 19 years and an oilhead RT owner for the next 9. This is my first experience with a Hexhead. Don’t (yet) know a lot about how they tick. I’ve read that the O2 sensors can be troublesome, Coil sticks having issues. I have a friend with a GS911, we were going to hook it up, see if there are trouble codes in there. I’d just feel better if it idled a little smoother, the noises at cold start concern me. maybe one of you hexheads could suggest a plan of attack. THANK YOU! Dave Link to comment
dirtrider Posted July 26, 2022 Share Posted July 26, 2022 2 hours ago, Dave P said: Hello Hexhead folks! I have a new to me 2007 R1200RT with 36k miles. It has a new battery this year. I just changed the oil last night with 20w50 conventional oil. No metal on the drain plug. At a cold start, it starts fine and idles pretty well, except I hear random taps / pops / noises. Noises are not at any regular intervals. From a couple of 1200RT friends I’ve mentioned this to, they say that the hexhead engine just does this. After about a minute or less, the tap sounds generally disappear, but the idle seems inconsistent, not smooth. Kinda bounces around, bike is shaky. Engine still hasn’t been running very long so I guess it’s still kinda cold. My morning commute is about 7 miles, rode it in today. Idles seems pretty good after 7 miles. I wouldn’t call it great, it still is a little bit lumpy, but it’s ok. Looks like it idles at about 1050- 1100 rpm. Seems maybe a tad low to me. Bike at speed seems to run well, has good power. Was planning to evaluate the easy stuff first- air filter, maybe pull the spark plugs, see what they look like. Run a nice fresh tank of premium ($$) gas through her, maybe with some Techron or Berrymans in the gas. I was an airhead RT owner for 19 years and an oilhead RT owner for the next 9. This is my first experience with a Hexhead. Don’t (yet) know a lot about how they tick. I’ve read that the O2 sensors can be troublesome, Coil sticks having issues. I have a friend with a GS911, we were going to hook it up, see if there are trouble codes in there. I’d just feel better if it idled a little smoother, the noises at cold start concern me. maybe one of you hexheads could suggest a plan of attack. THANK YOU! Dave Afternoon Dave On the noise question, THAT is very difficult to advise on without hearing and/or hearing & feeling it. You need to find a local hexhead owner & have them listen to it & compare to theirs. The idle speed is computer controlled so there isn't much you can do with that unless you can find a reason that it isn't idling correctly. If the battery was dead, replaced, or disconnected then you probably should do a new TPS re-learn. On the cold start & cold noises it could be a slightly oil fouled lower spark plug, or a lower stick coil causing you an issue, or a fuel injector not spraying cleanly due varnish build up. Maybe try putting some Techron concentrate in the fuel tank then riding a couple of tanks or Techron laced fuel through it (that might clear up your cold start & cold idle issues) Link to comment
Dave P Posted July 26, 2022 Author Share Posted July 26, 2022 DR- thank you for your reply. The PO did replace the battery recently so that TPS relearn is probably a good idea. How to do that? Sounds like examining the plugs is a good idea. If they aren't damaged I could probably clean them. Ive got a couple cans of Berrymans, could I run that through the gas? Thanks, Dave Link to comment
dirtrider Posted July 26, 2022 Share Posted July 26, 2022 24 minutes ago, Dave P said: DR- thank you for your reply. The PO did replace the battery recently so that TPS relearn is probably a good idea. How to do that? Sounds like examining the plugs is a good idea. If they aren't damaged I could probably clean them. Ive got a couple cans of Berrymans, could I run that through the gas? Thanks, Dave Evening Dave Ive got a couple cans of Berrymans, could I run that through the gas? -- You could but it probably isn't a good choice unless it contains a lot of Techron. You really want to use Techron if possible as that is the best product for cleaning the fuel system. TPS re-learn procedure----- *Disconnect the lead to the battery's positive post for about 3 minutes. Then *Reconnect the positive lead to the battery's positive post. Then *Switch on the ignition. (do not start engine) Then *Without starting the engine, fully open/close the throttle once or twice so that the control unit of the BMW engine management system can register the throttle-valve positions. Then *Switch off the ignition. That's it__ Link to comment
Dave P Posted July 27, 2022 Author Share Posted July 27, 2022 Thanks DR, I'll get some Techron tomorrow and gas her up! TPS- relearn, easy peasy! DP (I'm actually DRP) ha! 1 Link to comment
