wbw6cos Posted July 24, 2022 Share Posted July 24, 2022 I was doing some routine maintenance that required removing a lot of tupperware and discovered the exoansion tank does not have a hose n the top portion. There is a fitting for one and it looks like it is for an overflow hose because I see some retaining clips right below that open fitting. Is there supposed to be a hose attached Online microfiche shows only one hose from the bottom, but on my bike, that same hose goes to the neck of the radiator at the pressure cap. I could not find any hose that was not connected to anything, so I thought I would ask. Link to comment
MikeB60 Posted July 24, 2022 Share Posted July 24, 2022 I'd put one on there if you can route it to the bottom of the bike. If the engine ever overheats, not likely, it's gonna spit coolant all over the place. Link to comment
wbw6cos Posted July 24, 2022 Author Share Posted July 24, 2022 Thanks Mike. I am wondering why there is not one hooked up. Maybe a short one that fell off. (?) Or if there was ever one attached in the first place. Factory issue? Dealer issue? Besides, the coolant is low, as in, just enough at the very bottom. I have to buy some to add. Might as well purchase some hose while I am at it. Link to comment
Hati Posted July 25, 2022 Share Posted July 25, 2022 Someone asked the same question on "the other" BMW touring forum. The general view was that no hose was attached because no one has ever seen the bottle overflow. Hell, there is no mention of the coolant ever being replaced, so clearly overflow will never be an issue. 1 Link to comment
Rockosmith Posted July 25, 2022 Share Posted July 25, 2022 There was no hose there on either my ‘15 or ‘17 RT. Don’t see what it would hurt to put one on to avoid a potential mess. Link to comment
wbw6cos Posted July 25, 2022 Author Share Posted July 25, 2022 Thanks, Dave. Seems odd, doesn't it? My only concern at this point is the fluid level. Link to comment
Skywagon Posted July 25, 2022 Share Posted July 25, 2022 My 2014 RT has a hose there routed down Link to comment
TEWKS Posted July 25, 2022 Share Posted July 25, 2022 So, it seems like some of us are getting hosed while others are not. William you had to see that one coming. I’m going to go look right now If I can see without pulling parts that is. Link to comment
TEWKS Posted July 25, 2022 Share Posted July 25, 2022 I just revealed my RT ignorance. You can’t see anything while she’s dressed. Link to comment
wbw6cos Posted July 25, 2022 Author Share Posted July 25, 2022 Imagine that: a fireman talking about somebody getting hosed. 1 1 Link to comment
