lather Posted July 1, 2022 Share Posted July 1, 2022 My cruise control on my 2013 R1200RT stopped working. I decided to open up the switch and check the contacts and clean up any corrosion. There was some dirt and debris inside and I sprayed some electrical contact improver (Deoxit D5) and cleaned up with cotton swabs. It was a struggle to get the three connectors re- inserted into there slot but I got it done. However, now the windshield, horn and bright headlights don't work. Apparently my clumbsy arse has manged the switch further. Any help? Link to comment
dirtrider Posted July 1, 2022 Share Posted July 1, 2022 14 minutes ago, lather said: My cruise control on my 2013 R1200RT stopped working. I decided to open up the switch and check the contacts and clean up any corrosion. There was some dirt and debris inside and I sprayed some electrical contact improver (Deoxit D5) and cleaned up with cotton swabs. It was a struggle to get the three connectors re- inserted into there slot but I got it done. However, now the windshield, horn and bright headlights don't work. Apparently my clumbsy arse has manged the switch further. Any help? Afternoon lather Start by re-addressing the 3 connectors, make sure that you didn't bend a terminal pin. Link to comment
lather Posted July 1, 2022 Author Share Posted July 1, 2022 Thank you dirtrider, I will do that. Link to comment
lather Posted July 1, 2022 Author Share Posted July 1, 2022 No bent terminals that I can see. However, the Windshield motor is back in action. The horn and high beam still not working. The yellow "SET" light flashes on on ignition on. I have not ride tested yet (thunderstorms here today) to see if the cruise control is functional. I am guessing the cruise control does not operate if the bike is not moving. The high beam flasher does not feel right, the horn button feels normal. I will report back after a test ride. Thanks again Link to comment
dirtrider Posted July 2, 2022 Share Posted July 2, 2022 14 hours ago, lather said: No bent terminals that I can see. However, the Windshield motor is back in action. The horn and high beam still not working. The yellow "SET" light flashes on on ignition on. I have not ride tested yet (thunderstorms here today) to see if the cruise control is functional. I am guessing the cruise control does not operate if the bike is not moving. The high beam flasher does not feel right, the horn button feels normal. I will report back after a test ride. Thanks again Morning Let's hope you can get you switch's figured out & back to working again. On the cruise control issue__ That is usually the clutch lever switch acting up, not always but usually. The clutch lever has 2 separate switches, one is for starting inhibit & the other is the cruise control cut-out (keeps engine RPM's from flaring if the clutch lever is pulled in with the cruise set). You can run an in-place cruise test that might point you to at something in the cruise control system. First)- With the ignition switch OFF, switch on the cruise control. Then)- Press and hold the SET button to the SET position, then turn ON the Ignition switch (SET LIGHT should come on) Next)- Release the SET button (LIGHT THEN GOES OFF), move to RESET position (Resume) position (LIGHT SHOULD BE ON) Next)- Release the button (LIGHT SHOULD BE OFF) Next)- Switch OFF the cruise control switch (LIGHT SHOULD BE ON) Next)- Switch the cruise control switch back to on (LIGHT SHOULD BE OFF) Next)- Close (roll) throttle twist grip (all the way past normally closed). (LIGHT SHOULD BE ON), release throttle. (LIGHT GOES OFF) Next)- Pull in clutch lever (LIGHT ON), release clutch lever (LIGHT OFF) Next)- Pull front brake lever (LIGHT ON), release lever (LIGHT OFF) Next)- Push foot brake pedal (LIGHT ON), hold for 5 seconds (LIGHT SHOULD GO OFF), release foot brake pedal (LIGHT SHOULD BE ON) Next)- Rotate rear wheel (LIGHT SHOULD GO OFF/ON/OFF/ON) Last)- Switch off ignition. 1 Link to comment
lather Posted July 2, 2022 Author Share Posted July 2, 2022 Thanks again dirtrider. I will look at the clutch lever switches and try the cruise test. Link to comment
lather Posted July 2, 2022 Author Share Posted July 2, 2022 Just back from a 60 mile test ride and the cruise control worked flawlessly. I set it 8 or ten times and it always engaged without a problem. I believe my cleaning work did the trick, but unfortunately I seem to have mangled the hi beam switch and horn. I do have auxiliary lights and never ride at night anyway. A new switch is $600! Link to comment
beemer chuck Posted July 4, 2022 Share Posted July 4, 2022 Might want check with a dealer to see if your VIN number has had all the switch recalls done. Might get new switches under the recall. Link to comment
lather Posted July 5, 2022 Author Share Posted July 5, 2022 On 7/4/2022 at 10:22 AM, beemer chuck said: Might want check with a dealer to see if your VIN number has had all the switch recalls done. Might get new switches under the recall. I will do that, thanks. Yesterday the ESA would not work. It worked fine on the test ride the day before! Link to comment
