Tpoppa Posted June 28, 2022 Share Posted June 28, 2022 I'm sure this has been asked before. Is there a thread that talks about when (mileage) valves are likely to become out of spec, if at all? A BMW dealer told a riding buddy not to bother with the 12k check and wait until 24k on his GS. On my 2015 R12R, valves were in specs at 12k (hadn't moved at all). I plan to have them checked again a 24k in a couple months. If they are in spec at 24k, are they likely to move after that? Link to comment
duckbubbles Posted June 28, 2022 Share Posted June 28, 2022 I have 46K miles on my '17 RS and have checked them at 10, 20, 30 and 40K with no changes. I do my own maintenance and don't mind checking them that often. My previous '16 RS went over 20K without changes. I suspect that the wethead engines hold valve adjustment really well. If it were an upright 4 cyl. or a V-twin with difficult access I might think differently but our boxers are very easy to work on. Frank Link to comment
Dave_in_TX Posted June 28, 2022 Share Posted June 28, 2022 I did valve checks at 12k intervals but my 2014 R1200GS valves never needed adjustment. Link to comment
Geekmaster Posted June 29, 2022 Share Posted June 29, 2022 Since it's a quick and easy check on the boxer engine, why not do it and save some possible grief? While it is unlikely to need adjustment, it doesn't hurt to check. If it's within tolerance and you're happy with it (i.e. you don't want to try to get it close or below the mid-point), then you can just quickly button it back up and top off the oil (or finish the oil change) and you're done. 1 Link to comment
TSConver Posted June 29, 2022 Share Posted June 29, 2022 Check out boxflyers YouTube videos on it. 2 Link to comment
duckbubbles Posted June 29, 2022 Share Posted June 29, 2022 An item of concern that I did not mention is cam/cam follower wear. Lots of chatter on this and other forums about wear of these items. Gradually decreasing performance would probably go un-noticed by most riders and the metal flakes running around in the oil system cannot do any good. That and peace of mind knowing all is well. Frank Link to comment
realshelby Posted June 30, 2022 Share Posted June 30, 2022 A couple of the valves on my 2014 were in spec at 12K, but at the tightest end of the spec. By around 48K one was ever so slightly at or just under the spec. So, I shimmed those that were under the mid range so now all are near the middle of the spec range. I rather doubt I will need to do that again......Actually rather easy to do. Link to comment
Tpoppa Posted June 30, 2022 Author Share Posted June 30, 2022 I do most my own maintenance, but haven't attempted the valve check. Maybe I should. Getting a ride to drop off/pick up my motorcycle at the dealer is kind of a PITA. Link to comment
Dave_in_TX Posted June 30, 2022 Share Posted June 30, 2022 4 hours ago, Tpoppa said: I do most my own maintenance, but haven't attempted the valve check. Maybe I should. Getting a ride to drop off/pick up my motorcycle at the dealer is kind of a PITA. Checking valve clearence is fairly easy. Certainly less time than a round trip to dealer. In the rare event that you need a Shim changed, you can let dealer do it. Link to comment
Yeeha Stephen Posted June 30, 2022 Share Posted June 30, 2022 My last 1200 RT had 130K on it and valves were never out of spec. My 1250 RT has 56K on it and those are still in spec. You could always move them back to center just for fun if you feel like spinning some wrenches. SS Link to comment
JustKrusen Posted July 10, 2022 Share Posted July 10, 2022 68,000 miles on my 2016. Valves are still in spec. Link to comment
