Dingo55 Posted June 24, 2022 Share Posted June 24, 2022 help For the life of me I cannot figure out how the spring plate in the rear caliper sits Only thing I'm sure of (I think) is that that arrow points forward Is it supposed to clip into place somewhere or remain as a free floating item Thanks for any Help Cheers Mark Link to comment
Brodiepunker18 Posted June 24, 2022 Share Posted June 24, 2022 Pictures would help. I’m not sure exactly what you’re referring to. Link to comment
dirtrider Posted June 24, 2022 Share Posted June 24, 2022 1 hour ago, Dingo55 said: help For the life of me I cannot figure out how the spring plate in the rear caliper sits Only thing I'm sure of (I think) is that that arrow points forward Is it supposed to clip into place somewhere or remain as a free floating item Thanks for any Help Cheers Mark Morning Mark I don't have an 1100 picture handy but this 1150 is very similar. 1 Link to comment
Brodiepunker18 Posted June 24, 2022 Share Posted June 24, 2022 @dirtrider My caliper doesn’t have that…is that necessary? I just rebuilt it and it was already gone…what exactly is it for? Link to comment
dirtrider Posted June 24, 2022 Share Posted June 24, 2022 5 minutes ago, Brodiepunker18 said: @dirtrider My caliper doesn’t have that…is that necessary? I just rebuilt it and it was already gone…what exactly is it for? Morning Brodiepunker18 It is sort of an anti-rattle pad tension spring, it prevents pad rattle & keeps tension on the brake pads. You should probably relace it. Are you sure that your caliper doesn't have it but it is stuck in place? Link to comment
Brodiepunker18 Posted June 24, 2022 Share Posted June 24, 2022 @dirtrider without pulling the caliper off and checking, I’m pretty positive it’s not there. I rebuilt that caliper with new pads, seals and pistons. ( I did EVERYTHING—rebuilt all calipers,both master cylinders, new pads,lines,discs…) ill have to take a look after DART and see. Link to comment
Dingo55 Posted June 25, 2022 Author Share Posted June 25, 2022 Hi Thanks for that DR That was the only place it seemed to "fit" but wasn't certain as it just seems to float there Anyhow all back together Am curious as to how that piece actually works as it's hard to see with it back together Bet there is a lot of bikes cruising around without that piece in place Cheers Mark Link to comment
dirtrider Posted June 25, 2022 Share Posted June 25, 2022 5 hours ago, Dingo55 said: Hi Thanks for that DR That was the only place it seemed to "fit" but wasn't certain as it just seems to float there Anyhow all back together Am curious as to how that piece actually works as it's hard to see with it back together Bet there is a lot of bikes cruising around without that piece in place Cheers Mark Morning Mark It's function is pretty simple, it just keeps tension or pressure on the top of the brake pads so they don't rattle around. Link to comment
