Rotor Posted May 9, 2022 Share Posted May 9, 2022 Seems a lot of postings from me lately…sorry. While doing maintenance on my new-to-me 2005 RT I found the rear u-joint is bad. Bike has less than 20,000 miles on it (only reason I purchased it). To say I was surprised would be an understatement. No rust or anything like that, just a very pronounced bad spot – to the point you have to force it past that spot to get the joint to move. I have these questions: 1. I realize the joints weren’t intended to be replaced but I have heard it can be done? 2. If so, where would I purchase the parts? 3. Can any machine shop perform the replacement? 4. Would you trust a used shaft if one could be found? Hoping I didn’t purchase a money-pit but I’m finding many things not as the previous owner said they were. I knew I'd be spending some money on it but I didn't expect expenses of this nature considering the low miles. Thanks in advance. Link to comment
dirtrider Posted May 9, 2022 Share Posted May 9, 2022 2 hours ago, Rotor said: Seems a lot of postings from me lately…sorry. While doing maintenance on my new-to-me 2005 RT I found the rear u-joint is bad. Bike has less than 20,000 miles on it (only reason I purchased it). To say I was surprised would be an understatement. No rust or anything like that, just a very pronounced bad spot – to the point you have to force it past that spot to get the joint to move. I have these questions: 1. I realize the joints weren’t intended to be replaced but I have heard it can be done? 2. If so, where would I purchase the parts? 3. Can any machine shop perform the replacement? 4. Would you trust a used shaft if one could be found? Hoping I didn’t purchase a money-pit but I’m finding many things not as the previous owner said they were. I knew I'd be spending some money on it but I didn't expect expenses of this nature considering the low miles. Thanks in advance. Afternoon John 1. I realize the joints weren’t intended to be replaced but I have heard it can be done?--- Yes, but you basically need a lathe, dial indicators, & a TIG welder to do it. 2. If so, where would I purchase the parts?-- Those U joints are available but difficult to find as they are not made to be replaced. I had a source but with this Covid thing they can't source them for me any longer. 3. Can any machine shop perform the replacement?-- Yes, well sort of anyhow. They need to have access to a proper U joint plus have the ability to replace yours. Most could likely do it but by the time you (or they) source a U joint then might as well send that shaft to a proper drive shaft shop as they do many a week so are experienced in replacing those difficult to replace joints. (plus drive line/drive shaft shops like MSI usually install new greaseable U joints that can be lubricated every few years) 4. Would you trust a used shaft if one could be found?-- Depends, on if the used shaft has good joints in it. The early 1200 drive shafts were updated by BMW on later BMW 1200RT models. You might give (MSI) a call as they have replaced a LOT of BMW boxer U joints & do good work. Machine Service, Inc. Green Bay, WI 54304 Phone: (920)-339-3000 Link to comment
John Ranalletta Posted May 9, 2022 Share Posted May 9, 2022 1 hour ago, Rotor said: Don't know if this helps. Bought a reconditioned drive shaft for '05 GS. Had zero issues. https://www.motorworks.co.uk/parts/transmission.html?find=r-series-r1200-r1200rt--09-2004---08-2009--203&p=2&sid=8vOKWKUAzm Link to comment
Rotor Posted May 9, 2022 Author Share Posted May 9, 2022 Thanks D.R. I'll give them a call. Link to comment
Rotor Posted May 9, 2022 Author Share Posted May 9, 2022 Thanks John. Don't really want to order from that far but I will certainly keep it in mind. Regards Link to comment
dduelin Posted May 9, 2022 Share Posted May 9, 2022 I have a drive shaft in my 2007 RT that was refurbished by Machine Service Inc of Green Bay, WI. Dirtrider mentioned them above. The charge was $260 and the turnaround was one week when done two years ago. I didn't install it until 3,500 miles ago. There were some reports of reliability problems with MSI rebuilds back maybe 6-8 years ago but my research didn't turn up any problems in BMW forums since then. I called them and talked to the shop manager that does them. They do hundreds of u-joint replacements and shaft rebuilds each year since so I took this chance. The rebuild includes grease fittings on the u-joints. To get a spare drive shaft bought a fleabay "low miles" swing arm/final drive assembly including the shaft and lo and behold one of the U-joint bearings had a catch in it. The original one in my bike was in good shape with no catching or roughness but it had 120,000 miles on it and I wanted to replace it before trouble. Link to comment
Rotor Posted May 10, 2022 Author Share Posted May 10, 2022 1 hour ago, dduelin said: I have a drive shaft in my 2007 RT that was refurbished by Machine Service Inc of Green Bay, WI. Dirtrider mentioned them above. The charge was $260 and the turnaround was one week when done two years ago. I didn't install it until 3,500 miles ago. There were some reports of reliability problems with MSI rebuilds back maybe 6-8 years ago but my research didn't turn up any problems in BMW forums since then. I called them and talked to the shop manager that does them. They do hundreds of u-joint replacements and shaft rebuilds each year since so I took this chance. The rebuild includes grease fittings on the u-joints. To get a spare drive shaft bought a fleabay "low miles" swing arm/final drive assembly including the shaft and lo and behold one of the U-joint bearings had a catch in it. The original one in my bike was in good shape with no catching or roughness but it had 120,000 miles on it and I wanted to replace it before trouble. Hi Dave, I recognize you from another site. Thanks for the note. I'll be speaking with them tomorrow. Be well. Link to comment
