Scott9999 Posted May 9, 2022 Share Posted May 9, 2022 My H1 has a single pin or connector. My BMW RT's negative wire plugs directly into the headlight bracket, and the positive wire clips onto the H1 halogen bulb, just like everyone else's RT. However, my new H1 LED's, come with two pins, similar to my H7 low beam lamp. The vendor's instructions are simple, i.e. detach and plug that negative wire directly to the H1 LED pin, and plug the positive wire to the other pin. So, I have negative wire, a positive, wire two connectors on my H1 LED; it's all good. Except, which pin on the LED is positive, which is negative, or are they interchangeable as far as connecting the wires to the bulb? I'm pretty certain that this is a stupid question, i.e. probably interchangeable, because searching Google, I can't readily find the answer. (In other words, no one is THAT stupid that they even ask the question. 🙄) I have the question into the vendor, but ... well, never mind. Link to comment
Scott9999 Posted May 9, 2022 Author Share Posted May 9, 2022 Vendor said to hook pos/neg to either H1 LED pin, doesn't matter. We'll go with that. Link to comment
