TEDZ Posted May 2, 2022 Share Posted May 2, 2022 I've been using a Nomar to change tires for about 10 years, always on bikes without tire pressure monitors. I recently bought a 2013 R1200RT with the TPMS option. Where should I start with the NoMar bar in relation to the sensors so I don't make an expensive mistake? Link to comment
dirtrider Posted May 3, 2022 Share Posted May 3, 2022 12 hours ago, TEDZ said: I've been using a Nomar to change tires for about 10 years, always on bikes without tire pressure monitors. I recently bought a 2013 R1200RT with the TPMS option. Where should I start with the NoMar bar in relation to the sensors so I don't make an expensive mistake? Morning TEDZ Front tire___ Pry off the tire opposite the valve/tire pressure monitoring sensor (RDC sensor). Apply the lever to the rim at RDC sticker, to prevent the tire bead from damaging the RDC sensor. Rear tire___ Pry off the tire opposite the valve/tire pressure monitoring sensor (RDC sensor). Apply the lever to the rim at RDC sticker, to prevent the tire beam from damaging the RDC sensor. Basically you don't want to pull the tire beads into or against the RDC sensor. 1 Link to comment
TEDZ Posted May 3, 2022 Author Share Posted May 3, 2022 Thanks. The front is done and back on the bike. The rear will be tomorrow. Link to comment
