Rider1260 Posted April 17, 2022 Share Posted April 17, 2022 (2008 RT) So I was having intermittent EWS no starts , I was able to get the bike to start after repeated on off cycles. Ordered new ring antenna , same issue. Is it off to the dealer or is there another fix I am missing. Thanks Link to comment
dirtrider Posted April 17, 2022 Share Posted April 17, 2022 1 hour ago, Rider1260 said: (2008 RT) So I was having intermittent EWS no starts , I was able to get the bike to start after repeated on off cycles. Ordered new ring antenna , same issue. Is it off to the dealer or is there another fix I am missing. Thanks Afternoon Rider1260 Do you have access to a GS-911, that might show you something? It's usually the antenna ring, or the wire pigtail to/from the antenna ring, or a problem with one or more of the keys (have you tried all your keys, ONE at a time, with no other keys in the ignition switch area?) Does it start better (no EWS) if you move the motorcycle to a different area? (could be a stray RFI signal where it's at now) Link to comment
Rider1260 Posted April 18, 2022 Author Share Posted April 18, 2022 Thanks for the reply :) I just removed the Ring Antenna Connection , plugged in the new antenna ring put in my key in it and tried to start with the other key ( switched keys also ) like I have seen in youtube videos. Yes I have a 911 Ill hook it up tommorow , I would expect to see the EWS fail , anything else I should be looking for ?? Yes I tried both keys ( no difference ) As far as moving it around I've had it intermittently fail in several locations, Usually moving all devices away from the bike and cycling the ignition enough times will get me going BUT that's no way to live. it first happened late in the season last year. It has gotten progressively worse. It does not really seem to matter I've had trouble free days with Phone , IPass, GPS, Cardo all mounted to bike , I've had issues with no electronics near the bike. Link to comment
dirtrider Posted April 18, 2022 Share Posted April 18, 2022 10 hours ago, Rider1260 said: Thanks for the reply :) I just removed the Ring Antenna Connection , plugged in the new antenna ring put in my key in it and tried to start with the other key ( switched keys also ) like I have seen in youtube videos. Yes I have a 911 Ill hook it up tommorow , I would expect to see the EWS fail , anything else I should be looking for ?? Yes I tried both keys ( no difference ) As far as moving it around I've had it intermittently fail in several locations, Usually moving all devices away from the bike and cycling the ignition enough times will get me going BUT that's no way to live. it first happened late in the season last year. It has gotten progressively worse. It does not really seem to matter I've had trouble free days with Phone , IPass, GPS, Cardo all mounted to bike , I've had issues with no electronics near the bike. Morning Rider1260 You can poke around using your GS-911 (at least with the WiFi version), I haven't looked at a hexhead key status in a while so don't want to confuse you by missing a step (when I'm hands-on it's sort of a non-thinker). Start by going to___ Service functions, then BMSK (or BMSK adaptions), then to View Key Status. In any case if you have a newer GS-911 & your GS-911 is updated there are some key functions to look at. Link to comment
Rider1260 Posted May 24, 2022 Author Share Posted May 24, 2022 Well at least it seems to be fixed now , seems there was some failing wiring near the headstock , ended up taking it to my dealer took a bit to get to the bottom of the problem , just happy to ride again :) 2 Link to comment
