Randyjaco Posted March 30, 2022 Share Posted March 30, 2022 I now have 8k miles on my bike now (2017 RT). Initially I had some fuel issues which have been corrected and at 5k miles I did a 12k service (in February) and a GS911 check. With the exception of the valve timing being off a bit (corrected), everything came out good. So I figured that the engine is worn in and in excellent condition. Today I took a 200-mile ride out and back on some flat straight Texas roads with the cruise control set at 73 per the GPS. The end result 42 MPG. It is a little disappointing coming off a F800ST that got 55 MPG under the same conditions. Even my 12-year-old Prius gets 45 MPG at that speed. The bike is all stock, no mods except for a Quiet Ride windshield. I weigh 165#, so it is not carrying a lot of weight. The gas is standard pump 93 octane. The tires are Road 6 front and Road 4 rear at factory pressures. So does this mileage sound right to y'all or do I need to look for other problems? Link to comment
Red Posted March 31, 2022 Share Posted March 31, 2022 With that plastic tube extending into the tank from the filler, I find it hard to fill to the same level close enough to make a realistic calc of what my mileage is. It's darker than the inside of a cow in there and the tube is some extra terrestrial light absorbing plastic. I believe, but cannot prove that I'm getting somewhere just under 50 mpg on premium grade 10% corn gas. 1 Link to comment
Rinkydink Posted March 31, 2022 Share Posted March 31, 2022 I typically got about 43-45mpg on my ‘17. I always ran 89 octane and ran tire pressures 2 lbs. PSI above BMW recommendations. Bigger shield and those Texas headwinds could affect it also. 1 Link to comment
Geekmaster Posted March 31, 2022 Share Posted March 31, 2022 On 3/30/2022 at 6:46 PM, Randyjaco said: ... Even my 12-year-old Prius gets 45 MPG at that speed. I'd rather ride a R1200RT at 42 MPG than drive a Prius at 45 MPG. Just sayin' ... 1 2 1 Link to comment
Skywagon Posted March 31, 2022 Share Posted March 31, 2022 Randy… on my 14 I have a lifetime average of 46. If I run at 70 in no wind and the shield only up enough to block wind in the face, I get 48. Raise the screen or get strong headwinds and it will fall to 43 or so. Wind and shield position make a huge difference. The day you rode it was pretty windy here Same thing in my Tahoe. No or light wind 70mph, 25-26. Add 20 mph wind and mileage is 20-21 Link to comment
utahskies Posted April 19, 2022 Share Posted April 19, 2022 42 sounds a bit low to me at a steady 73. I would expect something closer to mid-to upper 40s, but as others have pointed out, wind will make a big difference. Link to comment
Randyjaco Posted April 19, 2022 Author Share Posted April 19, 2022 I just got rid of my Flapper valve and my gas mileage jumped to 46, so I am feeling better Link to comment
