Rogerl Posted March 27, 2022 Share Posted March 27, 2022 I have a 2013 R1200R. Today I pulled it into my shop to do the spring maintenance on the bike. I remembered that for my previous bike a 2008 R1200R I had bought a rubber ring that went between the gas filler cap and the recess in the gas tank to keep water from getting down in the cavity. The ring had a strange name like a abadeck ring. My 2013 did not have this ring either. I took the gas filler assembly off the fuel tank and the bottom of the recess had rust on it just like my 2008 did. I scraped off the rust and gave it quick coat of paint. I searched all over to try to find a link to this seal ring and could not find it. I looked in the BMW parts fiche and could not find it either. Does anyone know the ring I am talking about and where to get one? Thanks Roger L Link to comment
dirtrider Posted March 27, 2022 Share Posted March 27, 2022 12 hours ago, Rogerl said: I have a 2013 R1200R. Today I pulled it into my shop to do the spring maintenance on the bike. I remembered that for my previous bike a 2008 R1200R I had bought a rubber ring that went between the gas filler cap and the recess in the gas tank to keep water from getting down in the cavity. The ring had a strange name like a abadeck ring. My 2013 did not have this ring either. I took the gas filler assembly off the fuel tank and the bottom of the recess had rust on it just like my 2008 did. I scraped off the rust and gave it quick coat of paint. I searched all over to try to find a link to this seal ring and could not find it. I looked in the BMW parts fiche and could not find it either. Does anyone know the ring I am talking about and where to get one? Morning Roger Did that gasket look anything like this? Link to comment
dirtrider Posted March 27, 2022 Share Posted March 27, 2022 12 hours ago, Rogerl said: I have a 2013 R1200R. Today I pulled it into my shop to do the spring maintenance on the bike. I remembered that for my previous bike a 2008 R1200R I had bought a rubber ring that went between the gas filler cap and the recess in the gas tank to keep water from getting down in the cavity. The ring had a strange name like a abadeck ring. My 2013 did not have this ring either. I took the gas filler assembly off the fuel tank and the bottom of the recess had rust on it just like my 2008 did. I scraped off the rust and gave it quick coat of paint. I searched all over to try to find a link to this seal ring and could not find it. I looked in the BMW parts fiche and could not find it either. Does anyone know the ring I am talking about and where to get one? Thanks Roger L More__ There is also a water drain hole in the filler ring, the drain for that hole passes through a hose running inside the fuel tank then out through the fuel pump pass-through. The pipe running through the fuel pump pass-through tends to plug with dirt & rust therefore blocking the drain. You might spray some WD-40 in that drain hole to see if it comes out drain hose on L/H side of motorcycle behind L/H foot peg area. After spraying in WD-40 you can try LIGHTLY blowing air through that drain hole, but CAUTION: don't use high air pressure or you risk blowing the hose off inside fuel tank. I usually spray some WD-40 into that water drain hole a few times a year just to keep it open & prevent corroding the tube shut in the pump pass-through. Link to comment
Rogerl Posted March 27, 2022 Author Share Posted March 27, 2022 Yes, the gasket looked like the one in the picture. I can not remember where I bought it. I will look for the drain hose. Roger L Link to comment
dirtrider Posted March 27, 2022 Share Posted March 27, 2022 41 minutes ago, Rogerl said: Yes, the gasket looked like the one in the picture. I can not remember where I bought it. I will look for the drain hose. Roger L Afternoon Roger Euromotoelectrics has them (or had them anyhow) https://www.euromotoelectrics.com/product-p/ft-gasket903.htm I think they also sell them on E-Bay. https://www.ebay.com/itm/254271307603?hash=item3b33c03f53:g:oa0AAOSwUwtdDPy4 You might call Euromotoelectric just to make sure it will work for what you want. Link to comment
