Alba Posted February 23, 2022 Share Posted February 23, 2022 Evening, I'm looking for some insight on a 2013 GS (I don't believe you have the TE designation in the USA I'm UK based) I have read that as the 2013 was a first generation new model then 2014 would be a better option. Is there any validity in this? Thanks in advance. Link to comment
dirtrider Posted February 23, 2022 Share Posted February 23, 2022 56 minutes ago, Alba said: Evening, I'm looking for some insight on a 2013 GS (I don't believe you have the TE designation in the USA I'm UK based) I have read that as the 2013 was a first generation new model then 2014 would be a better option. Is there any validity in this? Thanks in advance. Evening Alba European/UK model years don't always match the USA models, are you looking at a camhead (oil-cooled) or a wethead (water-cooled)? Link to comment
Alba Posted February 23, 2022 Author Share Posted February 23, 2022 32 minutes ago, dirtrider said: Evening Alba European/UK model years don't always match the USA models, are you looking at a camhead (oil-cooled) or a wethead (water-cooled)? As ever thanks for the reply, in the advertisement it does not state which model, can i tell the difference visually? Link to comment
dirtrider Posted February 24, 2022 Share Posted February 24, 2022 13 hours ago, Alba said: As ever thanks for the reply, in the advertisement it does not state which model, can i tell the difference visually? Morning Alba Quick way is to look at what side the muffler is on. Left side is a camhead & right side is wethead. 1 Link to comment
TEWKS Posted February 24, 2022 Share Posted February 24, 2022 14 hours ago, Alba said: advertisement it does not state which model, can i tell the difference visually? If you’ve got pictures this should help you determine which model. 1 Link to comment
Alba Posted February 24, 2022 Author Share Posted February 24, 2022 7 hours ago, dirtrider said: Morning Alba Quick way is to look at what side the muffler is on. Left side is a camhead & right side is wethead. It's a wethead ... exhaust on the right Link to comment
Alba Posted February 24, 2022 Author Share Posted February 24, 2022 I've read that there could be exhaust issues with the wethead 2013 models, is this a small sample view? Any tips testing for it? Link to comment
dirtrider Posted February 24, 2022 Share Posted February 24, 2022 2 minutes ago, Alba said: I've read that there could be exhaust issues with the wethead 2013 models, is this a small sample view? Any tips testing for it? Afternoon Alba What are the specifics of the " exhaust issues" that you are referring to. Link to comment
Alba Posted February 24, 2022 Author Share Posted February 24, 2022 18 minutes ago, dirtrider said: Afternoon Alba What are the specifics of the " exhaust issues" that you are referring to. dirtrider Specifically " the emissions related flappy valve failing could require the replacement of the whole exhaust system north of the catalyst." Link to comment
dirtrider Posted February 24, 2022 Share Posted February 24, 2022 10 minutes ago, Alba said: dirtrider Specifically " the emissions related flappy valve failing could require the replacement of the whole exhaust system north of the catalyst." Afternoon Alba That exhaust flapper valve is more for noise emission control. Yes, those can & do freeze up sometimes. If you catch them early enough then no big deal to free them up to work good again. Some riders here in the U.S. just wire the valve wide open so it can't stick closed then ride it that way without issues. 1 Link to comment
