MotoNews Posted February 15, 2022 Share Posted February 15, 2022 Image: The recently introduced Harley-Davidson Sportster S has broken a 24-hour speed record, completing 1,951-miles at an average of 81mph View the full article Link to comment
duckbubbles Posted February 16, 2022 Share Posted February 16, 2022 I am curious as to EXACTLY what speed record they broke? The HD Sportster S record? I'll admit that it is an accomplishment to run at high speed for 24 hours but the record they set doesn't seem to be that high. I feel that a properly supported late model BMW could at least equal this if not completely blow it away. Am I wrong? Frank Link to comment
dirtrider Posted February 16, 2022 Share Posted February 16, 2022 9 minutes ago, duckbubbles said: I am curious as to EXACTLY what speed record they broke? The HD Sportster S record? I'll admit that it is an accomplishment to run at high speed for 24 hours but the record they set doesn't seem to be that high. I feel that a properly supported late model BMW could at least equal this if not completely blow it away. Am I wrong? Frank Morning Frank 81 mph average isn't very high for continuous high speed running but probably not too bad considering figuring 31 pit stops into that average. BMW might do better seeing as most have a higher top speed & hold more fuel (fewer pit stops). Link to comment
Hosstage Posted February 16, 2022 Share Posted February 16, 2022 Well BMW, ready to step up to the plate? Link to comment
Hosstage Posted February 16, 2022 Share Posted February 16, 2022 Just read the beginning of the article, this was a record for India, set at the Hero proving grounds. Link to comment
Red Posted February 17, 2022 Share Posted February 17, 2022 ''a new set of hoops every 1,000 miles'? Hoops = tires? Really? Just cuz the tires are hot shouldn't require that procedure. Iron butt folks may want to chime in. Link to comment
Hosstage Posted February 17, 2022 Share Posted February 17, 2022 3 hours ago, Red said: ''a new set of hoops every 1,000 miles'? Hoops = tires? Really? Just cuz the tires are hot shouldn't require that procedure. Iron butt folks may want to chime in. A little more extreme conditions than Iron Butt, maximum speed, maximum corner speeds, oval track, one side scrubbed much harder than the other. A little over 1900 miles, so one set of tires? And, safety. Max speed is no time for compromise. Link to comment
