IdahoArtie Posted December 20, 2021 Share Posted December 20, 2021 Can anyone tell me what size spark plug socket I need for my 2010 RT? I know it has to be thin and able to go deep. None of mine work and the bike didn't come with one in the kit under the seat so I'm lost on size. Thanks. Link to comment
Rougarou Posted December 20, 2021 Share Posted December 20, 2021 I use a standard Craftsman spark plug socket on my '06,.....dunno where the "thin" requirement is coming from, I know I didn't buy anything special and it slides right in. I believe I'm using a 5/8" socket,.....will have to wait until I get home to verify. Quite similar to the 2019 GSA, no special socket that I used. Link to comment
dirtrider Posted December 20, 2021 Share Posted December 20, 2021 55 minutes ago, IdahoArtie said: Can anyone tell me what size spark plug socket I need for my 2010 RT? I know it has to be thin and able to go deep. None of mine work and the bike didn't come with one in the kit under the seat so I'm lost on size. Thanks. Morning IdahoArtie You do need a thin walled deep socket. A 9/16" thin walled deep m-i-g-h-t work (at least for removal) as 9/16" is about 14.3mm 1 Link to comment
Skywagon Posted December 20, 2021 Share Posted December 20, 2021 There are a bunch of them on Amazon if you need it right away. Amazon.com : 14mm thin wall socket Link to comment
Rougarou Posted December 20, 2021 Share Posted December 20, 2021 41 minutes ago, dirtrider said: Morning IdahoArtie You do need a thin walled deep socket. A 9/16" thin walled deep m-i-g-h-t work (at least for removal) as 9/16" is about 14.3mm That's what it says, but that's not what I use NGK Laser Platinum Spark Plug (DCPR8EKP) Link to comment
dirtrider Posted December 20, 2021 Share Posted December 20, 2021 5 minutes ago, Rougarou said: That's what it says, but that's not what I use NGK Laser Platinum Spark Plug (DCPR8EKP) Morning Rougarou That -NGK DCPR8EKP (NGK DCPR8EKC) sounds like you are working on a hexhead not a camhead motorcycle are you sure that you are using the NGK DCPR8EKP in a 2010-2013 camhead motorcycle? Link to comment
Rougarou Posted December 20, 2021 Share Posted December 20, 2021 10 minutes ago, dirtrider said: Morning Rougarou That -NGK DCPR8EKP (NGK DCPR8EKC) sounds like you are working on a hexhead not a camhead motorcycle are you sure that you are using the NGK DCPR8EKP in a 2010-2013 camhead motorcycle? Ya, it's a hex, not a cam. But for the 2019 GSA, I still don't use a thin walled socket, just a standard Craftsman socket. My error on the plug choice Link to comment
dirtrider Posted December 20, 2021 Share Posted December 20, 2021 27 minutes ago, Rougarou said: But for the 2019 GSA, I still don't use a thin walled socket, just a standard Craftsman socket. Morning Rougarou Correct, but your 2019 doesn't have tight access lower spark plugs either. Link to comment
Rougarou Posted December 20, 2021 Share Posted December 20, 2021 5 minutes ago, dirtrider said: Morning Rougarou Correct, but your 2019 doesn't have tight access lower spark plugs either. The '06 doesn't seem to have the tight lower access either. So, wonder why the squeeze with the Cam's Link to comment
dirtrider Posted December 20, 2021 Share Posted December 20, 2021 3 minutes ago, Rougarou said: The '06 doesn't seem to have the tight lower access either. So, wonder why the squeeze with the Cam's Morning Rougarou They can vary a bit but I can't get a thick wall 6 point (all the way on) on the lowers of either of my hexheads. A thicker wall socket will sort of go part way on & the 12 point sockets will usually go on farther. A thinner wall fits all with full engagement. Link to comment
Rougarou Posted December 20, 2021 Share Posted December 20, 2021 1 minute ago, dirtrider said: Morning Rougarou They can vary a bit but I can't get a thick wall 6 point (all the way on) on the lowers of either of my hexheads. A thicker wall socket will sort of go part way on & the 12 point sockets will usually go on farther. A thinner wall fits all with full engagement. I'll take video next plug change Link to comment
IdahoArtie Posted December 21, 2021 Author Share Posted December 21, 2021 Thanks all. Just making a list for my first winter maintenance on this new to me 2010. Sounds like 14mm will work so need to add it to my list. Link to comment
lkchris Posted February 3, 2022 Share Posted February 3, 2022 The tool BMW has in its special tools program is Hazet 4766-2. https://chadstoolbox.com/hazet-4766-2-spark-plug-wrench/ Best price may be here https://www.bmwdirectparts.com/oem-parts/bmw-socket-wrench-insert-813010-83300495560?c=bD0xJm49U2VhcmNoIFJlc3VsdHM%3D Link to comment
