Skywagon Posted November 9, 2021 Share Posted November 9, 2021 (edited) I bought a roll of heat shrink tape from Amazon. I've always wanted to try it for wires that are still connected and can't get shrink tubing over. It came yesterday. Save your money. It neither shrinks or adheres to anything using a heat gun or a flame. It just lays flat. If you keep applying heat it disintegrates. Edited November 9, 2021 by Skywagon 1 Link to comment
TSConver Posted November 9, 2021 Share Posted November 9, 2021 I had some cold shrink wrap that worked well. Had to peel a backing off then wrap it. It was stuck after a few minutes. Link to comment
John Ranalletta Posted November 9, 2021 Share Posted November 9, 2021 5 minutes ago, Skywagon said: I bought a roll of heat shrink tape from Amazon. I've always wanted to try it for wires that are still connected and can't get shrink tubing over. It came yesterday. Save your money. It neither shrinks or adheres to anything using a heat gun or a flame. It just lays flat. If you keep applying heat it disintegrates. I use this 3M exclusively where shrink tube doesn't work. I've used it on trailer hitch wiring exposed to the elements. Once it's wrapped and sticks to itself for a while the only way to remove it is to cut it off. It's especially effective when you stretch it during application - the tape thins out, covers more area and makes for a smaller wire bundle. Link to comment
Skywagon Posted November 9, 2021 Author Share Posted November 9, 2021 Thanks John...I'll give it a try. I just tried the stuff I listed again. Nope..does absolutely nothing. Key for me is it has to be waterproof not water resistant. I wrap wires on a dock that gets a lot of salt spray and sometimes goes under water. Link to comment
John Ranalletta Posted November 9, 2021 Share Posted November 9, 2021 24 minutes ago, Skywagon said: Thanks John...I'll give it a try. I just tried the stuff I listed again. Nope..does absolutely nothing. Key for me is it has to be waterproof not water resistant. I wrap wires on a dock that gets a lot of salt spray and sometimes goes under water. Just tried a test. Wrapped a small piece around an old screwdriver and hit it with a small, lighter-type blowtorch. It seems to seal though wires will always have the crease where they are joined. As a last resort, I'd use this tape and some liquid rubber tape. The Rustoleum Leak Seal looks interesting but I've no experience with it. Link to comment
Indy Dave Posted November 9, 2021 Share Posted November 9, 2021 I ordered some "marine shrink tape with adhesive" last week, but have yet to test it on anything. I'll give it a go this evening and report back. Link to comment
eddd Posted November 9, 2021 Share Posted November 9, 2021 Here is what I've used for years. I was turned onto it when I installed antennas on towers. It provided the protection needed in harsh and hard to access locations. We always wrapped the Scotch 70 with layers of Scotch Super 33+ electrical tape, the best vinyl electrical tape available. Link to comment
Skywagon Posted November 9, 2021 Author Share Posted November 9, 2021 Thanks Eddd. Curious why you wrapped it over. I agree on 3M tape. That’s all I buy in electrical tape Link to comment
Indy Dave Posted November 10, 2021 Share Posted November 10, 2021 Whelp - I did rewire a tail light on my bike trailer last night, but since I soldered the wires, I was able to sue standard shrink tape. No test of the stuff I got. But soon. . . Link to comment
Skywagon Posted November 10, 2021 Author Share Posted November 10, 2021 Dave… do you recall what you bought and where. Link to comment
Indy Dave Posted November 10, 2021 Share Posted November 10, 2021 10 minutes ago, Skywagon said: Dave… do you recall what you bought and where. Not cheap . . . I bought this with the various sizes - thinking I'd have use for most of these sizes as time goes by. They have single size lengths as well. https://www.amazon.com/Ancor-301506-Electrical-Adhesive-Diameter/dp/B000NI075M Link to comment
Indy Dave Posted November 10, 2021 Share Posted November 10, 2021 Looking at this closer now, I'm not sure it's going to work as a 'wrap on' shrink tape? That's what I was looking for, and may have started clicking on other options - ending with this. I don't have it here at the house, it's at the shop. Tomorrow I'll head over and just do a test shrink and see if in fact you can use it on a assembled wire by wrapping it on. Link to comment
Skywagon Posted November 10, 2021 Author Share Posted November 10, 2021 Thanks I’ll wait until you post back. I’m not looking for cheap… looking for great wrap around waterproof for intact wiring. Not sue it exist so thought this board might know. On the boating website I’m on.. no help. They all say cut wires. Duh Link to comment
John Ranalletta Posted November 10, 2021 Share Posted November 10, 2021 44 minutes ago, Indy Dave said: Looking at this closer now, I'm not sure it's going to work as a 'wrap on' shrink tape? That's what I was looking for, and may have started clicking on other options - ending with this. I don't have it here at the house, it's at the shop. Tomorrow I'll head over and just do a test shrink and see if in fact you can use it on a assembled wire by wrapping it on. I think the photo showed shrink tubes. I've tried but failed in the past to slice them and shrink around wiring. Some have an adhesive coating inside so that may help. Link to comment
Lowndes Posted November 11, 2021 Share Posted November 11, 2021 This is the "self-fusing" tape I've benn using for 3-4 years with very good results on trailer wiring and such. I was skeptical at first and wrapped some around a screwdriver just like John did in above pics. For a while you can easily remove or reposition the tape but once it sits for a day, it becomes one piece, still just as flexible, but you'll have to cut it apart. If you stretch it slightly while applying it around wire, screwdriver, or pipe, it still has the same elastic-tight strength, but you have to hold it until it cures with a clamp or zip tie. Seems to be very weather and UV resistant. https://www.amazon.com/gp/product/B00HWRO744/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment
John Ranalletta Posted November 11, 2021 Share Posted November 11, 2021 7 hours ago, Lowndes said: This is the "self-fusing" tape I've benn using for 3-4 years with very good results on trailer wiring and such. I was skeptical at first and wrapped some around a screwdriver just like John did in above pics. For a while you can easily remove or reposition the tape but once it sits for a day, it becomes one piece, still just as flexible, but you'll have to cut it apart. If you stretch it slightly while applying it around wire, screwdriver, or pipe, it still has the same elastic-tight strength, but you have to hold it until it cures with a clamp or zip tie. Seems to be very weather and UV resistant. https://www.amazon.com/gp/product/B00HWRO744/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I think you'll find this tape very similar in sealing characteristics to the 3M. I've used both successfully. I recently added a trailer hitch to my 335ix. The taillight wiring is hidden in body panels necessitating drilling through the sheet metal behind the taillight assembly that is exposed to rain runoff. I used the 3M, layering two strands to capture the wiring and seal the 3/4" hole. Link to comment
Danny caddyshack Noonan Posted November 12, 2021 Share Posted November 12, 2021 Used self-fusing on rocket motor harnesses for additional thermal protection. Have it on the RT in several locations and it does not appear to have any aging issues. Non-silicone materials might otherwise harden. Link to comment
terryofperry Posted November 12, 2021 Share Posted November 12, 2021 For me it's: 3M Scotch 33+ for insulating elecrical connections 3M Scotch 23 for self fusing moisture protection or as mentioned the silicone version 70 3M Scotch 1755 Friction tape for outer wrap mechanical protection (abrasions, cuts (think firewall, etc) Something I haven't seen mentioned here, it's the stuff you cuss at when trying to get into a wire harness under the hood to make a tap. And 3M Scotchkote if real weather protection is desired. https://www.3m.com/3M/en_LB/p/d/v000260989/ https://multimedia.3m.com/mws/media/937488O/3m-rubber-mastic-specialty-tape-application-guide-lr-print.pdf Terry 1 Link to comment
Dennis Andress Posted November 12, 2021 Share Posted November 12, 2021 On 11/9/2021 at 1:52 PM, eddd said: Here is what I've used for years. I was turned onto it when I installed antennas on towers. It provided the protection needed in harsh and hard to access locations. We always wrapped the Scotch 70 with layers of Scotch Super 33+ electrical tape, the best vinyl electrical tape available. Thanks Ed! The Air Force equivalent originated from the F4 and was called ... Orange for engines. Black everywhere else. Link to comment
Indy Dave Posted November 12, 2021 Share Posted November 12, 2021 Whelp..... The former IndyCar electrical engineer at the shop (who was soldering and programming a bunch of boards when I came to see him today) recommends Raychem NR 1 tape. He says the stretch tape breaks down over time. The supply store on Gasoline Alley was out of it, but will get a roll next week (from England) for me. The engineer says it wasn't cheap, which I assumed meant it was $10-15. I thinks it going to be more like $100! Link to comment
Chris K Posted November 12, 2021 Share Posted November 12, 2021 I think you are right Dave. Mouser sells it for $ 105 a roll! Link to comment
Indy Dave Posted November 12, 2021 Share Posted November 12, 2021 Yikes. My friend's company builds electronic components that have to withstand all manor of environmental exposures, challenges, punishment and abuse. So I'm sure it's worth it to them to use this tape when the need arises. But for mere mortals like me, probably not so much. I think I'll pass on the tape! Link to comment
Lowndes Posted November 12, 2021 Share Posted November 12, 2021 1 hour ago, Indy Dave said: Yikes. My friend's company builds electronic components that have to withstand all manor of environmental exposures, challenges, punishment and abuse. So I'm sure it's worth it to them to use this tape when the need arises. But for mere mortals like me, probably not so much. I think I'll pass on the tape! WHAT!!?? You don't think "all manor of environmental exposures, challenges, punishment and abuse." includes flooding river crossings and mostly subsonic mountain road riding?? 2 Link to comment
Indy Dave Posted November 12, 2021 Share Posted November 12, 2021 Actually, I'm going to get the roll. These old 80's engine harnesses we're working on can use this stuff. We did redo one fuel injection harness, so it would present cleanly, now having this option may save us from doing that again. Link to comment
Indy Dave Posted November 12, 2021 Share Posted November 12, 2021 Looks like my cost will be $52 per roll. That's an easier pill to swallow. No idea when it's coming yet, but it's in stock in England and this supplier get a shipment from them every week. I'll report back when it arrives. Link to comment
Hank in WV Posted November 12, 2021 Share Posted November 12, 2021 Looks like you should be able to get two rolls at that price... Link to comment
Skywagon Posted November 12, 2021 Author Share Posted November 12, 2021 Indy Dave...be careful with that stuff. It sounds so powerful I would hate for your wife to have to call 911 to free your hands up. Anxious to hear how it works. 1 Link to comment
Indy Dave Posted January 17, 2022 Share Posted January 17, 2022 The tape came in about 2 weeks ago. Turns out coming from England took longer than they thought. I don't know if they were waiting for a larger order or what. The place that sells this tape has all kinds of HD electrical connector stuff used in professional racing, boating, etc. That said - I haven't tried the tape yet, as I went ahead and cleaned up the tail wiring on the RT with solider. However, I will have a use for the tape (I think) later this week. Link to comment
Hank in WV Posted January 17, 2022 Share Posted January 17, 2022 Off topic, Dave, just wondering about who makes that wheel in the backround. Link to comment
Indy Dave Posted January 18, 2022 Share Posted January 18, 2022 Hi Hank - Those wheels are from a (E39) 1998 BMW 540i - the green car on the lift. @Hank in WV Link to comment
SCOOTERTR6 Posted January 19, 2022 Share Posted January 19, 2022 I've been using a hair straightner for about a year to shrink heat shrink works great it heats up in ten seconds It shrinks the tubing way faster than a hair dryer it doesn't get hot enough to scorch the tubing or curl it working in tight spaces or wiring directly onto the bike is alot easier. and nothing catches on fire. They cost about 12 bucks. get one with aluminum heat surfaces Link to comment
