MachineJoe Posted October 15, 2021 Share Posted October 15, 2021 So I stop into my friends auto supply store and ask him for Dot4 and gives me Dot 3&4 Is this acceptable to use in our RT's? Link to comment
The Fabricator Posted October 16, 2021 Share Posted October 16, 2021 Yes. 4 has a higher wet boiling point than 3. No harm filling a 3 system with 4. Bottle contains 4 fluid, which works for old 3 systems. 1 Link to comment
dirtrider Posted October 16, 2021 Share Posted October 16, 2021 10 hours ago, MachineJoe said: So I stop into my friends auto supply store and ask him for Dot4 and gives me Dot 3&4 Is this acceptable to use in our RT's? Morning Machine Joe Yes, you are good-to-go with that fluid. Dot 4 can be mixed with, or used in place of DOT 3, but not the other way around as DOT 3 should not be used in place of DOT 4. If the brake fluid is specified as a DOT 3 & 4 that means it meets the DOT 4 specs (446°f dry boiling point). That is a sort of a marketing deal as it is basically a DOT 4 fluid that can be used in DOT 3 brake systems. 1 Link to comment
MachineJoe Posted October 16, 2021 Author Share Posted October 16, 2021 Thank you guys, I really do appreciate your input and experience. Link to comment
Dave_in_TX Posted October 16, 2021 Share Posted October 16, 2021 Not sure about previous models but BMW recommends low viscosity brake fluid for wetheads. 1 Link to comment
dirtrider Posted October 16, 2021 Share Posted October 16, 2021 1 hour ago, Dave_in_TX said: Not sure about previous models but BMW recommends low viscosity brake fluid for wetheads. Morning Dave Good point, we should have asked what motorcycle he is working with. Neither the 1100 ABS-II or the 11500 I-ABS require low viscosity DOT 4 brake fluid but BMW does currently sell low viscosity to use in those bikes. The newer BMW ABS bikes with the smaller ABS internal orifices' are speced to use low viscosity fluid though. Not sure if it makes a lot of difference unless ridden in very cold ambient temps then rider enters an ABS event. Link to comment
MachineJoe Posted October 16, 2021 Author Share Posted October 16, 2021 Sorry for not mentioning that the bike I'm referring to is a 2017 1200RT and I don't ride below freezing temps Link to comment
