Shelterwoods Posted September 18, 2021 Share Posted September 18, 2021 I'm looking to see if others have experienced this problem, and if anyone has come up with a fix. The windshield on my bike rattles when starting out at low revs. The problem is poor fit between the aluminum pins and the plastic frame that the shield attached to. Thanks for any help. Del Link to comment
Hati Posted September 18, 2021 Share Posted September 18, 2021 Had the same problem on my '06 RT. The holes were oversize for the pins used. I ended up cutting up some soft plastic tubing and squeezed it in around two of the four pins. It wasn't easy but it reduced the rattle greatly. Link to comment
Shelterwoods Posted September 19, 2021 Author Share Posted September 19, 2021 Thank you for the idea. I'll give it a try; I've got some thin plastic or rubber at home and will check it out when I get home from my ride. Del Link to comment
