StephenL Posted August 29, 2021 Share Posted August 29, 2021 Hi, my R1200RT 2005 speedo stopped working whilst riding in Manchester, very stop start. Any ideas? Oh, forgot to mention my bike has a disconnected ABS Link to comment
dirtrider Posted August 29, 2021 Share Posted August 29, 2021 27 minutes ago, StephenL said: Hi, my R1200RT 2005 speedo stopped working whilst riding in Manchester, very stop start. Any ideas? Oh, forgot to mention my bike has a disconnected ABS Evening StephenL Lots of possibilities on this one, probably the place to start is to make sure that you don't have a wheel speed sensor wire rubbing on the left front brake rotor. With a disconnected ABS that could effect the speed signal (depends on how it was disconnected). Otherwise you probably need to get a GS-911 on that motorcycle & check the front & rear speed signals. Link to comment
Dave Glen Posted August 30, 2021 Share Posted August 30, 2021 I've found a bad battery (low voltage) kicks off the Speedo failure as well as the cruise. I fitted a new battery problem gone. I have also done the absectomy leaving the electronic unit. Dave Glen Australia 2005 R1200RT Link to comment
StephenL Posted August 30, 2021 Author Share Posted August 30, 2021 Thanks, dirtrider and Dave, I’ll follow both these up. Stephen Link to comment
