Jerry_75_Guy Posted May 18, 2006 Share Posted May 18, 2006 So far this isn't a problem, but I can't help but wonder whether or not it might be a prodrome of electrical issues as yet not fully manifested: The left turn signal indicator on my instrument panel frequently (pretty much at every actuation, but starting at irregular time intervals after hitting the switch), will double it's flash rate. The right one behaves normally. I've made no recent changes to the bike, and through experiment have been unable to correlate this phenomenon with any other action or switch actuation. Gremlins not to be worried about?, or is a real problem developing?; I vaguely remember a writeup on similar brake light activity as a result of incompatable LED blub choices. Link to comment
Ken H. Posted May 18, 2006 Share Posted May 18, 2006 Mostly likely a corroded socket front or back or other similar high resistance point. Link to comment
Jerry_75_Guy Posted May 18, 2006 Author Share Posted May 18, 2006 Mostly likely a corroded socket front or back or other similar high resistance point. Assuming this is it, sounds like a little wire brush application and we're off to the races. I'll give it a shot. Thanks Ken! Link to comment
D. Boss Posted May 18, 2006 Share Posted May 18, 2006 This happened to me. The ground wire in the front directional came unplugged. Link to comment
Jerry_75_Guy Posted May 18, 2006 Author Share Posted May 18, 2006 This happened to me. The ground wire in the front directional came unplugged. I'm sure I'll find it in Clymers, but where is this plug? Link to comment
Uggles Posted May 18, 2006 Share Posted May 18, 2006 I'm sure I'll find it in Clymers, but where is this plug? ???? Bulb socket, wire on the back??? Link to comment
Jerry_75_Guy Posted May 18, 2006 Author Share Posted May 18, 2006 This happened to me. The ground wire in the front directional came unplugged. Bingo. That did it. Thanks I think the random time period between normal and rapid flashes was caused by the loose ground wire occasionally bumping it's contact on the bulb bracket. Don't get too excited Mark(Uggles) The last time I'd looked at, or even thought about those connections was when I installed the 'Runnin' Lites' several years ago; just had a little 'brain burp' Link to comment
