MarshMan Posted May 17, 2006 Share Posted May 17, 2006 Fired up the ST this morning for the ride to work. It's been pouring rain for 10 days straight--I really needed this. It was not to be: steady red warning light, rapidly blinking "brake failure" light. Manual sez I'm down to residual braking system, no ABS. Bike is rideable, but not for the 500-miler I had planned for this weekend. ARRRRGGHH! Doubly frustrating considering how I have babied this bike. Is there no avoiding a hellish trip to the dealer? Link to comment
Woodie Posted May 17, 2006 Share Posted May 17, 2006 This is quite possibly caused by a low battery at startup. I've had this happen on mine as well, after it's sat for a bit. Start the bike, ride for ~20 minutes (enough to top up the battery charge). Then stop, turn off the ignition, wait a few seconds, then restart. If it's just the battery, then the ABS warning lights should behave normally. One time, I rode all the way to work, still had the lights. Came out in the afternoon, and the brakes/warning lights had returned to normal. Finally, a nice day! (Yes, I got to ride in today!) Link to comment
Albert Posted May 17, 2006 Share Posted May 17, 2006 Also check the small abs wire running down the left fork leg to the caliper (assuming the ST is like the RT). I read (and found on mine) that the wire can be positioned so it rubs the rotor and would, presumably, wear through at some point. I found mine was barely touching and slid things further up in the wire retainer. If's your's has worn through it's probably a quick fix for the dealer anyway. Good luck. Link to comment
hophead Posted May 17, 2006 Share Posted May 17, 2006 I ride my ST every day and sometimes this still happens! It is the one legitimate gripe I have with the bike. There is a totally different feel to the brakes when you have only residual power as opposed to normal power. Be very careful! Why should you put up with a battery that loses significant power from sitting for only 10 days on a $16000 plus motorcycle? You aren't also grabbing the brake handle on startup are you? Link to comment
MarshMan Posted May 17, 2006 Author Share Posted May 17, 2006 I've only had the bike for 14 months...kept the battery topped up with the special extra-expensive BMW canbus charger all winter. Probably but 2,000 miles on it so far this spring with no problems. If it's simply a battery problem I guess I should be happy. I will keep you all posted. Link to comment
hophead Posted May 17, 2006 Share Posted May 17, 2006 This does not sound like a battery problem to me. Are you saying the failure mode persists and will not clear itself upon cool down and restart? Link to comment
MarshMan Posted May 17, 2006 Author Share Posted May 17, 2006 Opted not to take the bike to work so further testing will have to wait until tonight. Link to comment
