Monte Sloan Jr Posted May 24, 2021 Share Posted May 24, 2021 I am putting new brake pads on my R1200RT. Does it really matter if you install organic pads on the rear ? I am installing EBC sintered HH pads front and back. Thanks Link to comment
9Mary7 Posted May 24, 2021 Share Posted May 24, 2021 2 hours ago, Monte Sloan Jr said: Does it really matter if you install organic pads on the rear ? Only if you removed the ABS. The organics help soften the "bite" and are more controllable, but not necessary with the factory ABS as it will proportion brake pressure for you. EBC sintered HH work excellent on my RT. Link to comment
BamaJohn Posted May 24, 2021 Share Posted May 24, 2021 7 hours ago, Monte Sloan Jr said: I am putting new brake pads on my R1200RT. Does it really matter if you install organic pads on the rear ? I am installing EBC sintered HH pads front and back. Thanks My "once-only" use of organic pads on the rear of my '17 RT: they were worn down to metal in 5000 miles! Promised to not make that mistake again. 1 Link to comment
sleddriverSF Posted May 28, 2021 Share Posted May 28, 2021 On 5/23/2021 at 10:08 PM, 9Mary7 said: Only if you removed the ABS. The organics help soften the "bite" and are more controllable, but not necessary with the factory ABS as it will proportion brake pressure for you. EBC sintered HH work excellent on my RT. Do you know the EBC pad part number for front and back. I have looked on a couple sites and seen different numbers. I am new to my 2016 1200RT and want to be sure to get the right ones. Link to comment
strataj Posted May 28, 2021 Share Posted May 28, 2021 6 hours ago, sleddriverSF said: Do you know the EBC pad part number for front and back. I have looked on a couple sites and seen different numbers. I am new to my 2016 1200RT and want to be sure to get the right ones. EBC FA209/2HH Rear EBC Brakes FA630HH Double-H Series Sintered Disc Brake Pad Front 2 Link to comment
