Vesseli Posted May 12, 2021 Share Posted May 12, 2021 K 1200 LT -03 speedmeter not work, kilometers, and trip working normally, and ABS, cruice control also, but speedmeter needle only move zero when turn power on, after that nothing happend and not show driving speed.What can check and do ??. Speedmeter.MOV Link to comment
dirtrider Posted May 13, 2021 Share Posted May 13, 2021 On 5/12/2021 at 1:24 AM, Vesseli said: K 1200 LT -03 speedmeter not work, kilometers, and trip working normally, and ABS, cruice control also, but speedmeter needle only move zero when turn power on, after that nothing happend and not show driving speed.What can check and do ??. Speedmeter.MOV Morning Vesseli Due to the electronics involved it is very difficult to advise you what to check or do as you seem to have operational trip set & odometer. If your cruise control & ABS are working then your wheel speed signal is getting as far as the cruise control & ABS control unit so that part seems OK. If your odometer & trip set are working then the speed signal should be getting as far as the instrument panel control unit. From there on it is mainly in the electronics of the instrument panel control unit (I have no idea on how to test that). Link to comment
