neilsr1100rt Posted May 3, 2021 Share Posted May 3, 2021 Hello all. Looking for a bit of guidance on replacing the clutch adjustment screw for a 2000 R1100RT (see attached pics). Tried to adjust the clutch cable and the adjustment screw ended up snapping. A little too tight and too much force on my end. I've ordered a new adjustment screw and knurled nut to replace the existing. Question is do I have to remove the whole clutch cable? By gaining enough slack on the cable at the hand lever by loosening the 13mm bolt at the clutch, I'm hoping to remove the cable at the hand lever and replace the adjustment screw at that location. I've already unfastened the clutch cable from the lever but there is still enough tension on the cable that doesn't allow me to release the cable. How can this be achieved? After watching a few videos, I don't want to remove the whole right faring, wheel, etc. for only the adjustment screw. Any ideas would be greatly appreciated. Thanks for the input. Link to comment
dirtrider Posted May 3, 2021 Share Posted May 3, 2021 39 minutes ago, neilsr1100rt said: Hello all. Looking for a bit of guidance on replacing the clutch adjustment screw for a 2000 R1100RT (see attached pics). Tried to adjust the clutch cable and the adjustment screw ended up snapping. A little too tight and too much force on my end. I've ordered a new adjustment screw and knurled nut to replace the existing. Question is do I have to remove the whole clutch cable? By gaining enough slack on the cable at the hand lever by loosening the 13mm bolt at the clutch, I'm hoping to remove the cable at the hand lever and replace the adjustment screw at that location. I've already unfastened the clutch cable from the lever but there is still enough tension on the cable that doesn't allow me to release the cable. How can this be achieved? After watching a few videos, I don't want to remove the whole right faring, wheel, etc. for only the adjustment screw. Any ideas would be greatly appreciated. Thanks for the input. Evening neilsr1100rt I have always been able to get the cable to release at the hand lever by removing it from the lower lever. In your case that might not be possible as you still have that broken adjuster on the cable. I usually have to turn the adjuster all the way in to get enough slack to get the cable to release. You might have to use a Dremel or hacksaw to cut the knurled nut to split that off so you can then remove the broken adjuster piece from the cable. Link to comment
neilsr1100rt Posted May 4, 2021 Author Share Posted May 4, 2021 Hey Dirtrider. Appreciate the words of wisdom. I did head back to the garage and tinkered with the lower adjuster to get me enough slack at the hand lever. I was able to remove the keeper from the end of the cable so I think I've got a path forward once the parts arrive. I was also able to unscrew the broken adjustor for the ultimate repair. I'm understanding that this could be a little tricky but should work if I'm able to remove the keeper, replace the adjuster, kurled nut and then put back together. Once the new adjuster and the kurled nut arrive, I'm all over it. Thanks again for stepping up to share your knowledge. 1 Link to comment
