narcosis Posted April 16, 2021 Share Posted April 16, 2021 This is the sixth time I've removed and re-installed the front wheel and the following step always bothers me. When re-installing the front wheel, before tightening the axle, the manual states "Firmly compress the front forks several times." after taking the bike off the center stand. Okay, how? The only suspension movement I can get with my weight is when it's set as soft as possible, and then it's not much. How are other folks doing this? Link to comment
dduelin Posted April 16, 2021 Share Posted April 16, 2021 Hold the front brake while seated and pump the front suspension up and down. Is this what you mean? 1 Link to comment
narcosis Posted April 16, 2021 Author Share Posted April 16, 2021 47 minutes ago, dduelin said: Hold the front brake while seated and pump the front suspension up and down. Is this what you mean? Yes, that's what I've always done but it doesn't feel like the forks are compressing much. Maybe it doesn't take much. Is the test to ride with no hands and if the bike tracks straight then you've got it right? Link to comment
wbw6cos Posted April 16, 2021 Share Posted April 16, 2021 Sort of throttle it and jam on the brake? Link to comment
TEWKS Posted April 16, 2021 Share Posted April 16, 2021 The ignition should be on. Believe it or not, somehow the suspension is locked until either the key is turned or ignition button pushed. Link to comment
The Fabricator Posted April 16, 2021 Share Posted April 16, 2021 Trap tire against a wall, push up/down on the bars while seated. Link to comment
dirtrider Posted April 16, 2021 Share Posted April 16, 2021 1 hour ago, narcosis said: Yes, that's what I've always done but it doesn't feel like the forks are compressing much. Maybe it doesn't take much. Is the test to ride with no hands and if the bike tracks straight then you've got it right? Evening narcosis No, it has nothing to do with tracking as it is a single track vehicle. It has more to do with centering the forks on the axle so there is no side load therefore no binding or stiction in the forks during compression. 1 Link to comment
Lemans Posted April 17, 2021 Share Posted April 17, 2021 I wasn't aware of the suspension being locked when the ignition switch is off...how do you lock a spring? Before tightening the axle nut and pinch bolts, I roll the bike a few feet and hit the front brake. Remember to pump the lever to restore brake function or this could end badly. Link to comment
TEWKS Posted April 17, 2021 Share Posted April 17, 2021 When having the bike tied down to a trailer and understanding the tie down placement on the fork crossmember. It seems there would be a lot of weight (as you hit road irregularities) pounding down on the system that locks the spring. No? What is the purpose or benefit of this lock system? Never explored an answer to that nagging question till now. Link to comment
Rockosmith Posted April 17, 2021 Share Posted April 17, 2021 It is not the spring that gets ‘locked’ on the ESA bikes. When the ignition is off the damping, front and rear, go to full hard. When power is applied the shocks are powered to the damping level selected. 3 Link to comment
