TSConver Posted April 2, 2021 Share Posted April 2, 2021 So on the new to me 2011 R1200RT the previous owner installed what I think are Hyper-lights S32 rear brake and running lights and a Centech AP-1 fuse block on a relay controlled power input. Anyone have experience with either of these? Are they reliable? Looks like the hyper-lights and the garmin cradle is powered off the Centech. Link to comment
dirtrider Posted April 2, 2021 Share Posted April 2, 2021 45 minutes ago, TSConver said: So on the new to me 2011 R1200RT the previous owner installed what I think are Hyper-lights S32 rear brake and running lights and a Centech AP-1 fuse block on a relay controlled power input. Anyone have experience with either of these? Are they reliable? Looks like the hyper-lights and the garmin cradle is powered off the Centech. Afternoon TSConver The devises themselves are pretty decent & seem to function without issue. The problems I see & have to deal with are usually wiring related due to poorly made connections or improper wire routing. Form what I can see on your wiring it looks like it was done by someone that used decent wiring abilities. I can't see the actual wire connections themselves but from what I can see it looks decent. Link to comment
RandyShields Posted April 2, 2021 Share Posted April 2, 2021 I used that set up on some prior bikes before just wiring directly to the battery on more recent bikes. Worked well with no problems. Link to comment
