TEWKS Posted March 23 Chris, I have no idea how it happened (ya I do) but it appears I’ve reached the limit. Is there a way to delete some of the unwanted so I can continue with the wanted? Thanks! Share this post Link to post
chrisolson Posted March 23 6 minutes ago, TEWKS said: Chris, I have no idea how it happened (ya I do) but it appears I’ve reached the limit. Is there a way to delete some of the unwanted so I can continue with the wanted? Thanks! LOL , yeah we thought 1/2 gig of storage would be sufficient for attachments ... IIRC gallery image limitations are separate. I can temporarily enable it so you can delete any of your attachments, but doing so will leave a broken link where ever they appeared ... so determining the "unwanted" might be a bit of a problem ... particularly in any volume to make a difference. If you feel like at least looking , do an edit of your post above and then in the attachment panel ...click on "insert other media" and then "insert existing attachment" and it will open up with thumbnails of all of your attachments. I haven't enabled delete capability, but you can see whats there and size and the potential fallout of going that way. I think a better solution is I can create a special "heavy attachment" member group with increased limits with you as its charter member. Share this post Link to post
TEWKS Posted March 23 23 minutes ago, chrisolson said: I think a better solution is I can create a special "heavy attachment" member group with increased limits with you as its charter member. It almost sounds like I can consider this a win. Filled the basket first? Thanks Chris, I’ll check out your suggestion. Share this post Link to post
chrisolson Posted March 23 17 minutes ago, TEWKS said: Thanks Chris, I’ll check out your suggestion. You can PM me with any updates 1 Share this post Link to post
