Riverside Posted February 21 Hello All, Thank you in advance for any input you can provide. I have a problem with my 2004 R1150R ignition switch. When I turn it to the ON position it briefly flashes on then goes off. If I back it up slightly it will come on and the bike will start normally. If I trun the key a very small increment to the right it shuts down again. I can also duplicate this by pushing on the bottom of the plastic switch housing's right side. it started after a prolonged period of sitting in the garge during the rainy season here in Costa Rica coupled with a knee soreness, possibly also a result of the rainy season in CR. After some research, I am leaning towards it being a faulty switch unit. Having said that I have several questions for those of you more knowledgable that me about such things. 1. Is my diagnosis the likely cause of the problem, or could this be caused by some other defect in the key system? I have a chance to get a new switch brought in to the country in someone's luggage in a couple of weeks, but don't want to do that to find out it is something else. 2. I got some information from an earlier post regarding an R1150RT with a damaged key unit that had photos of the key lock, switch unit and the removal of the switch, from a while ago that was very helpful in showing me the removal of the switch. However, the discussion and photos showed a set screw holding in the plastic switch unit and mine does not appear to have screw, but rather something that looks like a compression pin. The attached photo is not great, but definately does not show a set screw as was shown in the older post. Inless there is a very small screw inside the metal tube. I have seen other posts that require drilling out the set pin and am assuming this is the case with my particular bike. 3. It appears that the screw/pin can be removed by taking the sport windshield bracket off the right side. Is this a reasonable assumption or must I remove the upper fork yoke and do the work on the bench and replace the yoke? Share this post Link to post
dirtrider Posted February 22 18 hours ago, Riverside said: Hello All, Thank you in advance for any input you can provide. I have a problem with my 2004 R1150R ignition switch. When I turn it to the ON position it briefly flashes on then goes off. If I back it up slightly it will come on and the bike will start normally. If I trun the key a very small increment to the right it shuts down again. I can also duplicate this by pushing on the bottom of the plastic switch housing's right side. it started after a prolonged period of sitting in the garge during the rainy season here in Costa Rica coupled with a knee soreness, possibly also a result of the rainy season in CR. After some research, I am leaning towards it being a faulty switch unit. Having said that I have several questions for those of you more knowledgable that me about such things. 1. Is my diagnosis the likely cause of the problem, or could this be caused by some other defect in the key system? I have a chance to get a new switch brought in to the country in someone's luggage in a couple of weeks, but don't want to do that to find out it is something else. 2. I got some information from an earlier post regarding an R1150RT with a damaged key unit that had photos of the key lock, switch unit and the removal of the switch, from a while ago that was very helpful in showing me the removal of the switch. However, the discussion and photos showed a set screw holding in the plastic switch unit and mine does not appear to have screw, but rather something that looks like a compression pin. The attached photo is not great, but definately does not show a set screw as was shown in the older post. Inless there is a very small screw inside the metal tube. I have seen other posts that require drilling out the set pin and am assuming this is the case with my particular bike. 3. It appears that the screw/pin can be removed by taking the sport windshield bracket off the right side. Is this a reasonable assumption or must I remove the upper fork yoke and do the work on the bench and replace the yoke? Morning Bob I can't tell much from the picture as it is too blurry to have decent detail. It is supposed to have a very small set screw under some red sealer. I do see signs of the old red sealer but can't tell much else from the picture. Someone might have stripped the set screw at one time so just drove a roll pin in to hold the switch in, or possibly some requirement in your country that requires a more permanent switch retention. Use something (like a dental pick) or sharp wire to remove anything soft & sealer like in that retention screw hole then see if you can post a clear picture. If it is a roll pin in that hole instead of a small set screw then you will probably have to remove the entire upper triple tree to work on it to get that darn pin out. (again, thoroughly pick ALL the junk out of that hole then post a very clear picture of what you are working with). It does sound like you have a failing ignition switch by the way you state that you back the key up slightly before it will power up properly. But that is something the person actually working on the motorcycle will have to determine by hands-on testing. Share this post Link to post
Riverside Posted February 22 Hi Dirtrider, Thanks for responding. Your input and photos in an earlier post were what I was refering to in this inquirey. You're talking to the person actually working on the motorcycle. Been playing with wrenches for a long time. Normally I would take an electrical problem I have not encountered before to someone more experienced, but the dealer is a 4 hour run to San Jose. Not anxious to get halfway there when it gives it up completely. It's a US delivered bike that I have had since 2013. It came to me with the original 5700 miles so the switch retension is OEM. I removed the red sealer to see if it was a set screw or a roll pin holding the switch in place. Other input told me it could be either. As luck would have it the roll pin is there. I tried several times for a better photo, but, the phone doesn't take a clear photo. (Can't seem to turn off the flash but will work on that.) If it needs to be drilled out I think I can do that if I remove the metal bracket holding the sport windscreen..... and maybe headlight. Right now I am more concerned about getting the diagnosis right. Hate to spend the $260 for a new ignition switch to find out the key mechanism is the problem. Any other tests I can try to rule out other possibilties? Share this post Link to post
dirtrider Posted February 22 Morning Bob It does sound like the switch is bad but you won't really know until you either try a new switch plugged in (don't even need to remove existing switch just to test new switch operation). Or remove your switch, try to disassemble it, then clean it out & inspect the insides. If it has some sort of a roll pin?????_ then you can try drilling that pin out with the switch assembly still in the motorcycle but you need to be very careful to drill exactly straight so as to not enlarge or alter the pin hole. You also have to be very careful to not expand that pin while trying to remove it, or it could make proper installation of the new switch very difficult. You might try using a tap that is just VERY SLIGHTLY larger than the pin's center hole. Put a proper fitting nut on the tap first then slide on a slightly larger nut (or piece of pipe or tube). Then screw that tap in JUST far enough to bite into the pin, then tighten the nut to see if will pull the pin out. Share this post Link to post
Riverside Posted February 22 Morning Dirtrider, I managed to turn off the phone's flash and get a better photo of the set screw hole. Good news! What I thought was a roll pin now looks like simply clean metal surrounding the hole. if you enlarge the photo you can see what looks like threads and (might be my imagination) a screw slot. Now, looking for a short jewelers screw driver to test that theory. Share this post Link to post
dirtrider Posted February 22 10 minutes ago, Riverside said: Morning Dirtrider, I managed to turn off the phone's flash and get a better photo of the set screw hole. Good news! What I thought was a roll pin now looks like simply clean metal surrounding the hole. if you enlarge the photo you can see what looks like threads and (might be my imagination) a screw slot. Now, looking for a short jewelers screw driver to test that theory. Morning Bob That is just what the little slotted screw looks like down in the threaded hole. (also why you need to clean the hole out to get a good look in there) Careful that you don't strip the screw slot (easy to do if screw is stuck), otherwise once screw is removed the switch should drop out the bottom. Share this post Link to post
Riverside Posted February 22 BMW Motorad.... such a love hate relationship. Can't turn the screw with the tools I have in the position it is in. Would putting the set screw a few degrees more around the circumference been such a hard thing to do????? Have to remove the windscreen/headlight brackets to get a straight shot at the screw head. The upper bracket fastener is a bolt that you can't get a wrench or socket on. It appears it was replaced as all the others are allen key and not hex head. Guess I will be grinding a socket or wrench to remove it. Will let you know how I make out. Thank you for the input. Share this post Link to post
dirtrider Posted February 22 10 minutes ago, Riverside said: BMW Motorad.... such a love hate relationship. Can't turn the screw with the tools I have in the position it is in. Would putting the set screw a few degrees more around the circumference been such a hard thing to do????? Have to remove the windscreen/headlight brackets to get a straight shot at the screw head. The upper bracket fastener is a bolt that you can't get a wrench or socket on. It appears it was replaced as all the others are allen key and not hex head. Guess I will be grinding a socket or wrench to remove it. Will let you know how I make out. Thank you for the input. Morning Bob Can you remove the handle from your little screwdriver, then bend the metal shank part to 90° so it is very short with just enough length to get into the screw hole? Thinks like this are not designed or built for service, they are designed for ease of assembly at the initial assembly level. Share this post Link to post
Riverside Posted February 22 I removed the headlight bracket instead. More bolts than I thought at first, but with patience I managed to get the switch out. Turning it off and on with a screwdriver I can put it over center and the power goes off. I'm guessing since we have very humid weather here the problem may be a corroded contact inside plastic switch. You every open one up? It doesn't look like something made to be disassembled. Concern would be getting it open and having springs and stuff fly all over the place. But, it is not working right now so really don't have much to lose. Share this post Link to post
dirtrider Posted February 22 23 minutes ago, Riverside said: I removed the headlight bracket instead. More bolts than I thought at first, but with patience I managed to get the switch out. Turning it off and on with a screwdriver I can put it over center and the power goes off. I'm guessing since we have very humid weather here the problem may be a corroded contact inside plastic switch. You every open one up? It doesn't look like something made to be disassembled. Concern would be getting it open and having springs and stuff fly all over the place. But, it is not working right now so really don't have much to lose. Afternoon Bob Be careful in taking that switch apart as there are (if I remember correctly) 4 little spring in there that can take off for the unknown. Get it ready to come apart then dissemble inside a plastic baggie. Share this post Link to post
Riverside Posted February 22 Great idea using a baggie. Wish I'd have thought of that several times in the past. Would have saved more than a little frustration. I have a couple of calls to make first to see if I can get a new switch. Escondido, CA BMW was where the bike was serviced for several years before moving to Costa Rica, and they have been very helpful in the past. And a Beemer friend of mine since our Army days recommended calling Tom at RubberChickenRacing whom he thinks might have some experience with this problem. Let you know what happens. Share this post Link to post
Hosstage Posted February 22 An old school though, but can it be hotwired, just a simple toggle switch wired in to bypass the keyed switch? Or is this a much more complicated system with a chip in the key, or some such? Just trying to think of a way to ride it without worrying about the switch failing until a new one can be had. Share this post Link to post
Riverside Posted February 22 Hi Hosstage, Have a couple of leads on the switch right now. Challange is getting it to Costa Rica resonably. I will put a toggle switch in as a temorary fix once I confirm a new one is coming. Not cutting the wire till I know I can get a switch to replace the malfunctioning one. If I can't get on soon, might try repairing the contact problem inside the plastic housing till I can get one. That doesn't work... then cut the wire. Share this post Link to post
dirtrider Posted February 22 58 minutes ago, Riverside said: Hi Hosstage, Have a couple of leads on the switch right now. Challange is getting it to Costa Rica resonably. I will put a toggle switch in as a temorary fix once I confirm a new one is coming. Not cutting the wire till I know I can get a switch to replace the malfunctioning one. If I can't get on soon, might try repairing the contact problem inside the plastic housing till I can get one. That doesn't work... then cut the wire. Evening Bob Just keep in mind that the ignition switch does more than just a simple on/off, with switch ON 12v comes out of the ign switch, then goes back into the switch on another terminal only to come out again on yet another terminal to run some of the lighting. Share this post Link to post
