David_R Posted May 11, 2006 Share Posted May 11, 2006 First time it's ever failed me. At least it was close to home. ’99 RT 65k miles. Drove home in the rain yesterday. Then this morning while doing 70 on the highway in a pouring rain, the engine just quit as if the kill switch was thrown. Engine cranks fine, seems to be getting fuel, won't fire. The same thing happened about 3k miles ago (although it wasn’t raining that day but I had been out in the rain the day before). Except that time I was able to restart it. Given the number of times I’ve read HES threads on this board, is the best course to first check the wiring to the hall sensor? Thanks for your suggestions, David Link to comment
John Ranalletta Posted May 11, 2006 Share Posted May 11, 2006 Sounds suspiciously like a Hall Effect Sensor failure. Item #1 in this picture: Link to comment
bmwmick Posted May 14, 2006 Share Posted May 14, 2006 First time it's ever failed me. At least it was close to home. ’99 RT 65k miles. Drove home in the rain yesterday. Then this morning while doing 70 on the highway in a pouring rain, the engine just quit as if the kill switch was thrown. Engine cranks fine, seems to be getting fuel, won't fire. The same thing happened about 3k miles ago (although it wasn’t raining that day but I had been out in the rain the day before). Except that time I was able to restart it. Given the number of times I’ve read HES threads on this board, is the best course to first check the wiring to the hall sensor? Thanks for your suggestions, David David, Yes, Check the HES wiring first (right under the upper clamp on the HES plate) BUT be ready to leave the bike where it is when you do this 'checking'. What happens, usually, is the insulation on the wires falls away like little hard chips when you disturb them. Either have another HES ready to install or have the bike out of the way. Mick Link to comment
David_R Posted May 14, 2006 Author Share Posted May 14, 2006 I am using the /oihead_hall_sensors/ pdf by Dana Hager as a reference. He calls for testing the HES wiring by connecting a LED light to the sensors. Is there any reason why a voltmeter can’t be used instead? The uninterrupted sensors read 13v. Interrupted, the top sensor reads about 10 volts but I can get it down to almost zero by manipulating the wiring harness. The lower sensor reads 2-3 volts but will go up to 10 when the harness is twisted. Am I correct in assuming that the sensors should read 0 volts when interrupted? That they don't indicates a short. /Dave Link to comment
bmwmick Posted May 14, 2006 Share Posted May 14, 2006 I am using the /oihead_hall_sensors/ pdf by Dana Hager as a reference. He calls for testing the HES wiring by connecting a LED light to the sensors. Is there any reason why a voltmeter can’t be used instead? The uninterrupted sensors read 13v. Interrupted, the top sensor reads about 10 volts but I can get it down to almost zero by manipulating the wiring harness. The lower sensor reads 2-3 volts but will go up to 10 when the harness is twisted. Am I correct in assuming that the sensors should read 0 volts when interrupted? That they don't indicates a short. /Dave Dave, The fact you can change the voltage by 'wiggling' the cable tells me your insulation is 'dust'. Mick Link to comment
bmwmick Posted May 16, 2006 Share Posted May 16, 2006 Dave, Have you deemed your insulation dead yet? Mick Link to comment
David_R Posted May 17, 2006 Author Share Posted May 17, 2006 No, hopefully I'll have time to tonight. However, I did check the coil with an ohm meter. The secondary wiring gave a reading of 7k ohms. The specs say it should be 13k. I don't know how to interpret that reading – does it mean the coil is shot? I’m guessing I should replace it. /Dave Link to comment
bmwmick Posted May 17, 2006 Share Posted May 17, 2006 No, hopefully I'll have time to tonight. However, I did check the coil with an ohm meter. The secondary wiring gave a reading of 7k ohms. The specs say it should be 13k. I don't know how to interpret that reading – does it mean the coil is shot? I’m guessing I should replace it. /Dave Nope, The Primary should measure 0.5 Ohms and the Secondary is 7.5K Ohms. The earlier coils measured 13K Ohms like is called for in the Manual but the coils were 'improved'. Mick Link to comment
David_R Posted May 19, 2006 Author Share Posted May 19, 2006 Mick - Thanks for clearing that up. I opened up the harness on the HES and the insulation is discolored and cracked. I'll email you regarding the rewired one that you have. Link to comment
