Dingo55 Posted January 24, 2021 Share Posted January 24, 2021 Appreciate any info Are the left/right head gaskets the same and do they go on a particular way around Cheers Mark Link to comment
Jim Moore Posted January 24, 2021 Share Posted January 24, 2021 11xx Head Gasket Replacement - in photos | Adventure Rider (advrider.com) Link to comment
dirtrider Posted January 24, 2021 Share Posted January 24, 2021 8 hours ago, Dingo55 said: Appreciate any info Are the left/right head gaskets the same and do they go on a particular way around Cheers Mark Morning Mark The same cyl head gasket is used for both sides so that means they have to be reversible. Just make sure that you have the correct head gasket for your engine, the early/late BMW 1100 engine used two different sized cylinder head locating dowels (bushings) a 12.5 mm & a 14.5 mm. Be sure to verify that the matching holes in the head gasket properly fit your cylinder-to-head locating dowel size so the gasket properly centers. Link to comment
Dingo55 Posted January 25, 2021 Author Share Posted January 25, 2021 Hi Thanks for the replies A couple more ?? if I may Can the rocker arm adjustment be done whilst the head is on the bench Mine came back from the machine shop and I was told that I didn't need to worry about it ( which I know is not correct) I can get a yellow and white valve feeler guage in which is still sloppy That's 0.45mm which is outside specs Have I understood this correctly? At what stage in the head reinstall/torque do the 3 smaller bolts get installed and tensioned and do they get re torqued at the 1000 km re torque? Many thanks Cheers Mark Link to comment
dirtrider Posted January 25, 2021 Share Posted January 25, 2021 1 hour ago, Dingo55 said: Hi Thanks for the replies A couple more ?? if I may Can the rocker arm adjustment be done whilst the head is on the bench Mine came back from the machine shop and I was told that I didn't need to worry about it ( which I know is not correct) I can get a yellow and white valve feeler guage in which is still sloppy That's 0.45mm which is outside specs Have I understood this correctly? At what stage in the head reinstall/torque do the 3 smaller bolts get installed and tensioned and do they get re torqued at the 1000 km re torque? Many thanks Cheers Mark Morning Mark Sort of, you can do a preliminary rocker arm end play adjustment on the bench then tighten the smaller bearing bolts but don't rely on that as being 100 % correct after the head is installed & torqued. One of the cylinder head studs goes through the lower bearing so that can change the adjustment when tightened. Just re-check it after cylinder head installation, you definitely don't want to end up with a tight rocker arm that is below minimum specs or you could stick a valve & bend one or more of your valves. You are better off with them a little loose than a little tight. Link to comment
Dingo55 Posted January 27, 2021 Author Share Posted January 27, 2021 Hi. Thanks for that So far so good R/H head back on L/H head off and in for clean up Had the 'O' ring at rear of TB issue How important an item is that? Ended up doing the 90/90 torque procedure by eye (is that acceptable?) I noticed on the fiche diagrams there is a exhaust gasket ring No sign of anything like that on my bike (Do they burn up?) At the top end of the exhaust prior to the three hole plate on each pipe there is a rotatable collar (30mm long) Curious as to its purpose Thanks again Cheers Mark Link to comment
dirtrider Posted January 27, 2021 Share Posted January 27, 2021 1 hour ago, Dingo55 said: Hi. Thanks for that So far so good R/H head back on L/H head off and in for clean up Had the 'O' ring at rear of TB issue How important an item is that? Ended up doing the 90/90 torque procedure by eye (is that acceptable?) I noticed on the fiche diagrams there is a exhaust gasket ring No sign of anything like that on my bike (Do they burn up?) At the top end of the exhaust prior to the three hole plate on each pipe there is a rotatable collar (30mm long) Curious as to its purpose Thanks again Cheers Mark Morning Mark Had the 'O' ring at rear of TB issue-- What "O" ring problem are you having? Anything rear of the throttle plate has little effect on engine running but can effect dirt entry into the engine. How important an item is that?-- Important enough to replace if it's missing or damaged. Ended up doing the 90/90 torque procedure by eye (is that acceptable?)-- As long as you started at the correct low "initial" torque then got the 90°/90° fairly close it will be OK. You are going to have to (should anyhow) re-torque after riding a short time anyhow. I noticed on the fiche diagrams there is a exhaust gasket ring No sign of anything like that on my bike (Do they burn up?)-- No they don't burn up but sometimes they can still be in the cyl head exhaust ports & not look like they are there. Did yours get removed when the head was worked on? Look in each exhaust port "VERY CLOSELY" for an exhaust ring being present. They are usually seated it there pretty tight & not very noticeable. At the top end of the exhaust prior to the three hole plate on each pipe there is a rotatable collar (30mm long) Curious as to its purpose-- Those are there to allow the 3 hole plate to clamp the pipe tight to the gasket rings up inside the cyl head pocket. Link to comment
Dingo55 Posted January 27, 2021 Author Share Posted January 27, 2021 Thanks for your reply Working the intake manifold back onto the TB disturbed the 'O' ring on the rear of the TB I remember reading somewhere that it was fairly common as the 'O' ring expands or something I will have another look but don't recall anything resembling a gasket on the exhaust or in the head exhaust port Would you happen to know what mechanics use to mark items that have been torqued? Some sort of marking pen? Appreciate all your help Cheers Mark Link to comment
dirtrider Posted January 27, 2021 Share Posted January 27, 2021 9 minutes ago, Dingo55 said: Thanks for your reply Working the intake manifold back onto the TB disturbed the 'O' ring on the rear of the TB I remember reading somewhere that it was fairly common as the 'O' ring expands or something I will have another look but don't recall anything resembling a gasket on the exhaust or in the head exhaust port Would you happen to know what mechanics use to mark items that have been torqued? Some sort of marking pen? Appreciate all your help Cheers Mark Morning Mark Yes, those "O" rings can expand when removed. If you have decent "hot" sun still shining in your area then just put the "O" ring out in the hot sun for a few hours, that usually dries out the hydrocarbons & reduces the swelling. On marking (indexing) the bolts or nuts? I use a special commercial indexing marking paint (we use it where I work), otherwise just find a "Security Check Paint Marker". Possibly available at your local auto-parts store or at a machinists supply company. Also available on-line. Link to comment
Dingo55 Posted January 30, 2021 Author Share Posted January 30, 2021 Morning all Some more queries if I may Got my R/H ( burnt valve) head back on Took L/H head in but the guy is too busy to get to it so he quickly did some air pressure tests of some sort All good Came home decided to pre set valves and rocker arm clearances on the deck before install (checking after head torqued down) Absolutely no gap/movement at the rocker arm. None Zero Zilch Unfortunately I didn't check that on the R/H head before it went to the machine shop No idea how that has come about Does that part tighten up to that extent simply through use? Are the rocker arm bearing caps torqued to 15nm? Appreciate all the help Cheers Mark Link to comment
Dingo55 Posted January 30, 2021 Author Share Posted January 30, 2021 Hi I've asked about the rocker arm torque figure because I have seen 9nm, 15nm and 20nm as being the correct figure Confused Cheers Mark Link to comment
dirtrider Posted January 30, 2021 Share Posted January 30, 2021 11 hours ago, Dingo55 said: Morning all Some more queries if I may Got my R/H ( burnt valve) head back on Took L/H head in but the guy is too busy to get to it so he quickly did some air pressure tests of some sort All good Came home decided to pre set valves and rocker arm clearances on the deck before install (checking after head torqued down) Absolutely no gap/movement at the rocker arm. None Zero Zilch Unfortunately I didn't check that on the R/H head before it went to the machine shop No idea how that has come about Does that part tighten up to that extent simply through use? Are the rocker arm bearing caps torqued to 15nm? Appreciate all the help Cheers MOrning Mark What parts tightened up, the rocker arm end play or the valve lash? Link to comment
dirtrider Posted January 30, 2021 Share Posted January 30, 2021 10 hours ago, Dingo55 said: Hi I've asked about the rocker arm torque figure because I have seen 9nm, 15nm and 20nm as being the correct figure Confused Cheers Mark Morning Mark Tightening torque__ M-8 screws in rocker shaft bearing cap= 15 Nm M-8 screws for camshaft bearing cap= 15 Nm Link to comment
Dingo55 Posted January 30, 2021 Author Share Posted January 30, 2021 Morning DR The rocker arm had no up/down movement at all The last time this bike had major work was when the clutch was replaced (professionally) and was serviced at the end of that process So the 3x T45 torx head bolts on the rocker arm bearings are torqued to 15nm? Thanks for your help Cheers Mark Link to comment
dirtrider Posted January 30, 2021 Share Posted January 30, 2021 4 minutes ago, Dingo55 said: Morning DR The rocker arm had no up/down movement at all The last time this bike had major work was when the clutch was replaced (professionally) and was serviced at the end of that process So the 3x T45 torx head bolts on the rocker arm bearings are torqued to 15nm? Thanks for your help Evening Mark Yes, service manual calls for 15nm on the 1100, I usually go just slightly higher as the 1150 manual calls for 18nm (about the same setup between 1100 & 1150). Link to comment
