NOLONGERRELEVANT Posted December 29, 2020 Share Posted December 29, 2020 These lights don't turn on with any switch I can find on my bike? Any ideas? Link to comment
dirtrider Posted December 29, 2020 Share Posted December 29, 2020 5 minutes ago, NOLA Kirk said: These lights don't turn on with any switch I can find on my bike? Any ideas? Afternoon NOLA Kirk See if they come on with the high beam light. If not then jut chase the wire back to it's source. That is kind of a dangerous place to mount lights, looks like the fender could contact a light at suspension compression with the wheel turned (not a likely thing but it sure could happen at some time while riding). Link to comment
NOLONGERRELEVANT Posted December 29, 2020 Author Share Posted December 29, 2020 I might just remove them then. They do LOOK pretty cool there, but not worth causing a loss of control situation. Link to comment
Michaelr11 Posted December 29, 2020 Share Posted December 29, 2020 53 minutes ago, NOLA Kirk said: These lights don't turn on with any switch I can find on my bike? Any ideas? Follow the + wire from the lamps backwards. There is a chance that there is an in line fuse in the + wire. Or you might see where it terminates and see what is controlling it. Put a voltmeter on the + wire, see if it is hot. Maybe the negative wire is broken. I have a set of running lights in the same position on the same bike. Never had the lamps hit the front fender/wheel. Link to comment
Doctare Posted December 29, 2020 Share Posted December 29, 2020 I bought an R1150R from an engineer that added extra lights with a control module that toggled them on and off with the ignition switch. I have to turn the bike off and restart it to turn them on or off. Also if I stall out they toggle on/off. Link to comment
Dave P Posted December 29, 2020 Share Posted December 29, 2020 Nola- this is how my Piaa lights are mounted, just uses some aluminum tubes as standoffs and extra long bolts. Dave Link to comment
Sam Taylor Posted December 30, 2020 Share Posted December 30, 2020 Back in the day (turn of the century), there was a product called the Autoswitch. It was a sold-state switch programmed to turn on or off the load if you pressed and held the turn-signal cancel switch for about a second or two. It came with a small amber pilot light to blink during the switching process and stay lit when the load was on. I installed several of these on my Beemers over the years. The one I have now has been working since 2002 to control my PIAAs--incidentally mounted where yours are with no issues. 1 Link to comment
NOLONGERRELEVANT Posted January 6, 2021 Author Share Posted January 6, 2021 Still haven't figured these lights out. Night time didn't help nor did covering the additional item with tape. Also tried pressing the blinker release button for two seconds as someone recommended, but still nothing. Plan on doing some voltmeter work later today. Link to comment
