Dave P Posted December 17, 2020 Share Posted December 17, 2020 Hello, 96 R1100RT, I'm trying to rebuild the feeble and broken little plastic bosses that attach the RID to the inner fairing (I call it dashboard) it would be nice to unplug the RID so I can match it up and get the 3 new bosses positioned correctly and glued in. That connector is way up there, is there a trick to disconnecting that block or do I need to take the whole nose off? Dave Link to comment
Michaelr11 Posted December 18, 2020 Share Posted December 18, 2020 If you remove the dash panel and then unscrew the RID from the panel, you should have all the room that you need. I have repaired the legs of my RID with JB Weld. JB makes a plastic epoxy too. Apply some of the JB Weld to the broken area and then also apply some to the outside, over the cracks. It should hold. Try to press the rubber indents gently when changing the time of the clock. Link to comment
Dave P Posted December 18, 2020 Author Share Posted December 18, 2020 Michael- Thanks for the note, but I'm trying to remove the RID, completely. Trying to unplug it from the connector. I did think tonight that if I remove the right side snorkle tube, it might give me more room to reach in there and disconnect that white block. D Link to comment
Michaelr11 Posted December 18, 2020 Share Posted December 18, 2020 11 hours ago, Dave P said: Michael- Thanks for the note, but I'm trying to remove the RID, completely. Trying to unplug it from the connector. I did think tonight that if I remove the right side snorkle tube, it might give me more room to reach in there and disconnect that white block. D Remove the RID permanently? Once the dash is removed, the front fairing isn't that difficult to remove. You might be able to just tip the fairing to give you access. I've had the front fairing off 2 or 3 times. After the first time, it's not that hard. I have a set of lights attached to the bottom of the front fairing. That adds to the job. Link to comment
Dave P Posted December 18, 2020 Author Share Posted December 18, 2020 Well I just want to unplug it, use it loose to measure and rebuild those bosses, and then hook it back up and put it all back together. Not going to delete it, just unhook it temporarily. my book says you have to take the whole windshield mechanism out to take that painted nose piece off. I had it off 8 years ago when I painted the bike but I don't remember taking that mechanism out. D Link to comment
Michaelr11 Posted December 18, 2020 Share Posted December 18, 2020 24 minutes ago, Dave P said: my book says you have to take the whole windshield mechanism out to take that painted nose piece off. I had it off 8 years ago when I painted the bike but I don't remember taking that mechanism out. D Nope. You have to remove the screen itself, not the motor. That's just 4 screws - watch out for the little gaskets under the plastic. Link to comment
Dave P Posted December 18, 2020 Author Share Posted December 18, 2020 Crazy, weak little plastic bosses to hold that RID in place. I bet most if these old RTs have JB Weld glopped all over those bosses. D Link to comment
Warren Dean Posted December 19, 2020 Share Posted December 19, 2020 2 hours ago, Dave P said: Crazy, weak little plastic bosses to hold that RID in place. I bet most if these old RTs have JB Weld glopped all over those bosses. D Mine sure does. Pretty poor design but JB Weld saved the day. Link to comment
Dave P Posted December 19, 2020 Author Share Posted December 19, 2020 Adding 3 little bosses with brass inserts, need to locate them and neatly epoxy in place. D Link to comment
AndyS Posted December 22, 2020 Share Posted December 22, 2020 On 12/19/2020 at 12:24 AM, Warren Dean said: Mine sure does. Pretty poor design but JB Weld saved the day. I wouldn't say it was poor design. Those RID units have now been around for well over 20 years sitting in the crazy heat and freezing cold. They have done pretty well. Link to comment
Warren Dean Posted December 22, 2020 Share Posted December 22, 2020 10 hours ago, AndyS said: I wouldn't say it was poor design. Those RID units have now been around for well over 20 years sitting in the crazy heat and freezing cold. They have done pretty well. Opinions vary on what constitutes a good design or not.... Link to comment
AndyS Posted December 23, 2020 Share Posted December 23, 2020 13 hours ago, Warren Dean said: Opinions vary on what constitutes a good design or not.... Fait enough. but tell me what is poor about that design (over anything else on that bike). For example, a lot of the fabric cable tape across the whole bike is rotting away, does that make it a bad design? The insulation on the HES cable degrades...well, that is a bad design with the insulation not being fir for service. Items like the RID seem perfectly fit for the expected service life of the bike. Link to comment
Warren Dean Posted December 23, 2020 Share Posted December 23, 2020 1 hour ago, AndyS said: Fait enough. but tell me what is poor about that design (over anything else on that bike). For example, a lot of the fabric cable tape across the whole bike is rotting away, does that make it a bad design? The insulation on the HES cable degrades...well, that is a bad design with the insulation not being fir for service. Items like the RID seem perfectly fit for the expected service life of the bike. Who said anything about the rest of the bike? The statement was in reference to the RID mounting design. Link to comment
AndyS Posted December 23, 2020 Share Posted December 23, 2020 My question/statement holds true...what is wrong with the design of the RID? Link to comment
Warren Dean Posted December 23, 2020 Share Posted December 23, 2020 35 minutes ago, AndyS said: My question/statement holds true...what is wrong with the design of the RID? I am not going to get into an internet pissing contest with you. You win. Link to comment
AndyS Posted December 23, 2020 Share Posted December 23, 2020 It's not about winning. What the gripes is the fact that you slag off the design of something without grounds. But like you, for the sake of all the other readers, I will draw a line under this. 1 Link to comment
Warren Dean Posted December 23, 2020 Share Posted December 23, 2020 That's awfully nice of you. Link to comment
Dave P Posted December 27, 2020 Author Share Posted December 27, 2020 I really just meant that the bosses that attach that RID are too small, would work better if they were beefier with some threaded inserts. I love the RID itself. Dave 1 Link to comment
Warren Dean Posted December 27, 2020 Share Posted December 27, 2020 11 hours ago, Dave P said: I really just meant that the bosses that attach that RID are too small, would work better if they were beefier with some threaded inserts. I love the RID itself. Dave Precisely. That is my argument, hence the view that it is a poor design. I would bet a dollar, cash American, that most, if not all, get broken when the bike gets washed from pressing too hard on the face. Mine (2nd hand) came pre-broken . That will never happen again thanks to JB Weld. Link to comment
Dave P Posted January 20, 2021 Author Share Posted January 20, 2021 Here's what I did, might put lock washers on under those plastic screw on barrels. Dave 2 Link to comment
Warren Dean Posted January 21, 2021 Share Posted January 21, 2021 Very nicely done. BMW should have done that to begin with. Link to comment
