Motor32 Posted December 14, 2020 Share Posted December 14, 2020 Hey Guys, Since I got my bike back after they replaced the mode button, I've been having an issue with the volume going between normal and soft. It does this on it's own and I took it back to the dealer and of course it didn't do it, so I made these 2 videos today when it was acting up. Any thoughts??? Thanks, Steve https://www.youtube.com/watch?v=tsgPjhuabsQ https://www.youtube.com/watch?v=vG_N_3X7wDo Link to comment
reg26 Posted December 15, 2020 Share Posted December 15, 2020 You might want to tell us all the year and options of your bike Please Link to comment
Motor32 Posted December 15, 2020 Author Share Posted December 15, 2020 1 hour ago, reg26 said: You might want to tell us all the year and options of your bike Please It's a 2020 that's stock. The dealer replaced a defective mode button then this issue started. Steve Link to comment
Bernie Posted December 15, 2020 Share Posted December 15, 2020 If you check your Audio System guide, you find a section where it explains how to adjust the speed-dependent volume control. Maybe it is set to a low level, causing the increase and reduction in volume? It is explained on page 25 of section 3 of this guide. Link to comment
Motor32 Posted December 15, 2020 Author Share Posted December 15, 2020 11 hours ago, Bernie said: If you check your Audio System guide, you find a section where it explains how to adjust the speed-dependent volume control. Maybe it is set to a low level, causing the increase and reduction in volume? It is explained on page 25 of section 3 of this guide. I thought that too but it made no difference if it was on or off. Steve Link to comment
dirtrider Posted December 15, 2020 Share Posted December 15, 2020 13 hours ago, Motor32 said: Hey Guys, Since I got my bike back after they replaced the mode button, I've been having an issue with the volume going between normal and soft. It does this on it's own and I took it back to the dealer and of course it didn't do it, so I made these 2 videos today when it was acting up. Any thoughts??? Thanks, Steve https://www.youtube.com/watch?v=tsgPjhuabsQ https://www.youtube.com/watch?v=vG_N_3X7wDo Morning Steve Usual place to start the troubleshooing is to go back to the last thing done to the motorcycle just before the problem started. In your case it was the "mode button" replacement so that is probably where you should start looking. Play your videos to your dealer as proof that you have an issue AFTER they just worked on that motorcycle. Link to comment
Motor32 Posted December 15, 2020 Author Share Posted December 15, 2020 1 hour ago, dirtrider said: Morning Steve Usual place to start the troubleshooing is to go back to the last thing done to the motorcycle just before the problem started. In your case it was the "mode button" replacement so that is probably where you should start looking. Play your videos to your dealer as proof that you have an issue AFTER they just worked on that motorcycle. I sent them the videos also and I'm just waiting to hear back from them. Steve Link to comment
