Mike c white Posted December 14, 2020 Share Posted December 14, 2020 Just bought 2008 k1200gt 36000 mi. Has chattering when in neutral with clutch lever out. Seems like might have a bit to much driveline noise on deceleration. Any input would be appreciated Link to comment
dirtrider Posted December 14, 2020 Share Posted December 14, 2020 7 minutes ago, Mike c white said: Just bought 2008 k1200gt 36000 mi. Has chattering when in neutral with clutch lever out. Seems like might have a bit to much driveline noise on deceleration. Any input would be appreciated Morning Mike It sounds like neutral gear rattle but not enough base info to tell you much as we can't hear it, or ride it, or listen as the clutch is disengaged/re-engaged in neutral. Does it sound quieter with a cold engine than with a warm engine? Does the rattle go away when you raise the engine RPM's slightly?? Link to comment
Mike c white Posted December 14, 2020 Author Share Posted December 14, 2020 I will check on those thanks Link to comment
KBMWGT Posted December 17, 2020 Share Posted December 17, 2020 cam chain warranty work done? Link to comment
Dennis Andress Posted December 18, 2020 Share Posted December 18, 2020 The cam chain tensioner works off oil pressure. The chain will slack and make noise for a few seconds when the engine is first started. Item #16 in this is part of a recall BMW did. Call your local dealer's service department with your VIN and ask if there are any outstanding recalls. Link to comment
