SageRider Posted May 10, 2006 Share Posted May 10, 2006 I'm looking for an antenna mount to fit the R1200-RT. I will use it for HAM radio antenna, but a CB mount is typically also able to be used. Is there anything available??? Link to comment
R4ND0M_AX3 Posted May 10, 2006 Share Posted May 10, 2006 I was just searching for a GMRS solution myself. Didn't find anything 100% yet. Might just take a CB type NGP and use an antenna tuned for the frequencies I want. Link to comment
Dennis_n1kcl Posted May 10, 2006 Share Posted May 10, 2006 I'm looking for an antenna mount to fit the R1200-RT. I will use it for HAM radio antenna, but a CB mount is typically also able to be used. Is there anything available??? Diamond luggage rack mount bolted to one of the passenger grab rails. I've had it on two different bikes and no marks on the rails are left and no holes in the bike. Link to comment
SageRider Posted May 10, 2006 Author Share Posted May 10, 2006 Dennis, Thank you for the input. Do you ever ride 2-up? If yes, is there any interference between antenna and the passenger? What is the maximum power you are transmitting? Also, do you have either of the BMW trunks? (I have the large unit which will be used when I am 2-up.) Link to comment
Dennis_n1kcl Posted May 10, 2006 Share Posted May 10, 2006 Dennis, Thank you for the input. Do you ever ride 2-up? If yes, is there any interference between antenna and the passenger? What is the maximum power you are transmitting? Also, do you have either of the BMW trunks? (I have the large unit which will be used when I am 2-up.) Wife has no problem with the antenna mount at all. Click on the link below and you can see how it mounts vagely. Now I'm only running 5wts through a VX-5, but plan on mounting my Ft-90 in the radio bay with the remote faceplate somewhere not yet determined. Link to comment
lewd40 Posted May 14, 2006 Share Posted May 14, 2006 I visited my friendly Harley dealer who donated an antennae mount used on a dresser. It attaches easily to the rear of my left bag. I installed a CB antennae (truckstop grade) and it functions beautifully. Link to comment
smiller Posted May 14, 2006 Share Posted May 14, 2006 What frequency? Assuming the usual VHF/UHF, I'd look for a half-wave antenna or something designed to work without a ground plane... should give better performance on a motorcycle and make the mounting location less critical. Link to comment
SageRider Posted May 14, 2006 Author Share Posted May 14, 2006 Seth, I'm installing a dual band 2M/440Mhz antenna. Based on earlier posts, I used a Comet RS-560C mount on the passenger hand rail with a Comet 3D4M cable kit. Results are poor. 1) Antenna interferes with seated passenger. 2) My Comet SBB1 and SBB2 SWR readings are both unacceptable on 2M, but fine on 440MHz. 3) 2) My Comet SBB5 antenna SWR is great on both bands, but is more antenna than I wish to use for general hooning. So, at this point, I'm still looking for an acceptable mount, then I'll get serious about the SWR issues. Link to comment
