LBump Posted November 27, 2020 Share Posted November 27, 2020 The R1100S has been sitting and I noticed the other day there was brake fluid on the wheel, rotor and caliper. Only on one side. I assume a seal went out... So, I guess it's time to do a rebuild on the calipers. Question is: anything overly complicated about this, anything I should avoid etc. Link to comment
dirtrider Posted November 27, 2020 Share Posted November 27, 2020 8 minutes ago, LBump said: The R1100S has been sitting and I noticed the other day there was brake fluid on the wheel, rotor and caliper. Only on one side. I assume a seal went out... So, I guess it's time to do a rebuild on the calipers. Question is: anything overly complicated about this, anything I should avoid etc. Afternoon LBump Northing complicated as they are pretty well straight forward same as most other 4 piston calipers. Unless you absolutely have to do not take the caliper half's apart. If you buy your new seals from BMW they are pretty darn expensive as the BMW kit comes with new piston as well as seals. You might search aftermarket (or Beemer Boneyard) as you can probably find just the seals (no pistons for a lot less$$$). 1 Link to comment
9Mary7 Posted November 27, 2020 Share Posted November 27, 2020 Delboy's Garage on youtube has some great vids on rebuilding calipers...... 1 Link to comment
Oldrider51 Posted November 27, 2020 Share Posted November 27, 2020 If you have access to compressed air it will make it easier to remove the pistons from the body. You would need to block two on one side first, then blow out the others by slowly introducing the air pressure. 1 Link to comment
BrianM Posted November 29, 2020 Share Posted November 29, 2020 On 11/27/2020 at 3:06 PM, 041100S said: If you have access to compressed air it will make it easier to remove the pistons from the body. You would need to block two on one side first, then blow out the others by slowly introducing the air pressure. If you do this, be careful. Watch out for your fingers when using compressed air, even with pressure turned down. Link to comment
