Car 54 Posted November 20, 2020 Share Posted November 20, 2020 Sent my ABS module off to Module Masters today. Should arrive Late next week. Holiday will probably mess that up. ‘07 R1200RT. Link to comment
Brunhilde Posted November 20, 2020 Share Posted November 20, 2020 How many miles on it? What symptoms of failure? Link to comment
Hati Posted November 20, 2020 Share Posted November 20, 2020 Is that a servo assisted version? IIRC they change in '07 to the next model ABS is why I'm asking. Link to comment
GordonB Posted November 20, 2020 Share Posted November 20, 2020 My '07 was non-servo. Link to comment
Rougarou Posted November 20, 2020 Share Posted November 20, 2020 My '06 got the whizzy brakes,....they still be a whizzying at 140k. Link to comment
Car 54 Posted November 22, 2020 Author Share Posted November 22, 2020 I am original owner. Build date 0207. Milage is about 15,550. Started to get intermittent “Brake Failure” light on dash after I started moving. Got more frequent then stayed on all the time. Also noticed I was not hearing ABS motor spinning up with start. Bike has Gen II ABS. Still have original fuel strip though. Keeping fingers crossed. John Link to comment
dirtrider Posted November 22, 2020 Share Posted November 22, 2020 10 hours ago, Car 54 said: I am original owner. Build date 0207. Milage is about 15,550. Started to get intermittent “Brake Failure” light on dash after I started moving. Got more frequent then stayed on all the time. Also noticed I was not hearing ABS motor spinning up with start. Bike has Gen II ABS. Still have original fuel strip though. Keeping fingers crossed. John Morning John Sounds like possibly a sticking motor brush in the rear servo motor (happens occasionally on the I-ABS gen II systems). Link to comment
Car 54 Posted November 23, 2020 Author Share Posted November 23, 2020 Hi DR, My thoughts exactly. The first time I noticed the problem was springtime when I pulled it out of cold storage after winter. It went slowly downhill from there. As the brakes worked fine individually I did not worry about ir too much although I did flush the brake fluid throughout but without success. Disassembly was interesting. Still trying to figure if I can do any other work on the bike while I have all the plastic off. First bike with ABS. Best, John Link to comment
Car 54 Posted November 30, 2020 Author Share Posted November 30, 2020 ABS module arrived in Idaho today. Thanksgiving held it up for several days. Hope they find what I think is the problem. Fingers crossed. John Link to comment
Car 54 Posted December 7, 2020 Author Share Posted December 7, 2020 I received a call from Module Masters a few minutes ago. My ABS unit is done and will be shipped. I inquired about issued they might have found and was informed it was the brushes. Just as I hoped/suspected. Also inquired about the fix and possible preventive measures. They stated they use a better quality brush set during the repair process and no suggested remedy otherwise. Cost was $250 plus shipping. Will install as soon as I get it back and installed but have snow on the ground so no road test until the roads are clean. I will post results when that happens. Best, John Link to comment
Tech1 Posted January 2, 2021 Share Posted January 2, 2021 On my 05 I bypassed/disabled the whizzy brakes and abs. I used a replacement pcm unit from RH Electronics called their Second Life Kit. I did the "lite" version, which is only the pcm, but I think I would have spent the extra dollars to get the regular unit if I did it again to make replacement a bit simpler. So far, I am good with it, but didn't get to ride it much before the season change here. I wish I had abs, but no more whizzy brakes and no more worries about it failing. One reason I didn't go with Module Masters was the wait. I am debating if I should keep the brake unit, sell the unit as is, or get it updated by them and then sell it. If only there was a way to update to the newer abs without the whizzy brakes. Gary Link to comment
Car 54 Posted February 27, 2021 Author Share Posted February 27, 2021 Good evening, Been away for awhile and was just reading through posts. I realized I never got back on the results. I reinstalled the rebuilt ABS, bled the system very well and waited for a clear driveway which took awhile. As I am back in the woods in rural MA with a 1,000’ driveway, I thought I would have to wait for some time. In early January I did have a snow free driveway so out came the bike. Rolled it out of my shop, turned towards the drive and started it up. Warmed for two minutes or so, put it in gear and moved off. Brake failure light went out in less than 20 feet. Drove to the end of the driveway and back and no return of the light. Seems good to go but need to wait till spring for a really good ride. Feel of the brakes was rock solid. First application of the brake was more noticeable than in recent memory but may just have been kicking in for the first time since rebuild. Anything changes I will advise. Best, John Link to comment
