MichiganBob Posted November 8, 2020 Share Posted November 8, 2020 Good Evening, You wouldn't think this would be so difficult. I was pleased when I moved to the 2018 RT to have the battery on the side figuring that accessibility would be easier than it was on my earlier models. There is a plastic plate that goes on the end which has two plastic nipples one on each side that go into a hinge and another nipple on the bottom. However the fit is so tight that I can't get the plate to fasten on the bottom. The nipple hole is inset too far. I've tried to rearrange the battery cables to get more clearance but no dice. I'm thinking of cutting off the bottom nipple of the plate as there is also a rubber strap and it fits so tight that the battery isn't going anywhere. But I hate to give up. I'm not sure what year the RT started mounting the battery on the side but was thinking that someone out there has had to change their battery with this configuration and figured out how to get this plate to fit . All advise is welcomed and appreciated. MB Link to comment
Boxflyer Posted November 8, 2020 Share Posted November 8, 2020 MB, the Riders Manual describes remove/install with images, but leaves out some fine details about how to really do this. The way to get this done is to finish up the wiring connections and have the insulation blanket installed (if you have one) then when sliding the battery back into the tray leave about 3/4 inch of the battery hanging out of the opening. This is the point that you put the small plate with the 3 tabs up against the end of the battery like it would be in it's home position. Now, using the plate, lift the plate and the battery that is supported by the lower tab up about 1/2 inch and slide it further into the tray so that when the side pins are aligned with their designated holes the bottom pin will also be aligned, so lower the plate and battery so that all the pins engage at the same time. Then finish up with hooking and securing the rubber keeper and it's all back in place. 3 Link to comment
wbw6cos Posted November 8, 2020 Share Posted November 8, 2020 I, too, find this procedure a little tricky. Thank you for the pointer. Link to comment
Cap Posted November 8, 2020 Share Posted November 8, 2020 2 hours ago, Boxflyer said: MB, the Riders Manual describes remove/install with images, but leaves out some fine details about how to really do this. The way to get this done is to finish up the wiring connections and have the insulation blanket installed (if you have one) then when sliding the battery back into the tray leave about 3/4 inch of the battery hanging out of the opening. This is the point that you put the small plate with the 3 tabs up against the end of the battery like it would be in it's home position. Now, using the plate, lift the plate and the battery that is supported by the lower tab up about 1/2 inch and slide it further into the tray so that when the side pins are aligned with their designated holes the bottom pin will also be aligned, so lower the plate and battery so that all the pins engage at the same time. Then finish up with hooking and securing the rubber keeper and it's all back in place. Need a video. 2 Link to comment
MichiganBob Posted November 8, 2020 Author Share Posted November 8, 2020 Thanks Boxflyer, I'll give it a try today. MB Link to comment
Boxflyer Posted November 8, 2020 Share Posted November 8, 2020 2 hours ago, Cap said: Need a video. Battery Tray Install480.mov 4 1 Link to comment
Cap Posted November 8, 2020 Share Posted November 8, 2020 23 minutes ago, Boxflyer said: Battery Tray Install480.mov 14.06 MB · 3 downloads Nice! thanks. Cap Link to comment
wbw6cos Posted November 8, 2020 Share Posted November 8, 2020 Apparently, my Shift Cam RT has a slightly different plastic cover, but it looks like it may be the same procedure. Thanks for showing that. Link to comment
MichiganBob Posted November 9, 2020 Author Share Posted November 9, 2020 Good Evening, It worked. Many thanks Boxflyer. MB Link to comment
MichiganBob Posted November 9, 2020 Author Share Posted November 9, 2020 Great video. In my original email I called them dowels, then changed it to nipples which left me a little unsettled. "Pins" is much better. LOL MB Link to comment
92Merc Posted November 9, 2020 Share Posted November 9, 2020 BTW, the cover on my 2015 is NOT the same as my wife's 2017. So they changed design in just 2 years. Still the pins, but the plastics are quite a bit different. Link to comment
old_farmer Posted December 12, 2021 Share Posted December 12, 2021 Y'all are a few steps ahead of me. I can't get the danged cover off. I pull the tab outward as described in the manual. Nothing budges. I try to pull up and out. It seems to move a bit but doesn't let go. And that's using pliers to pull with. What's the secret? Link to comment
old_farmer Posted December 12, 2021 Share Posted December 12, 2021 Got some help with this and got it off. And with Boxflyer's video, I think I can get it put back together. Link to comment
wbw6cos Posted December 12, 2021 Share Posted December 12, 2021 Yeah, I just lucked out on mine and could not describe to you on how. Congrats! Link to comment
Rinkydink Posted December 13, 2021 Share Posted December 13, 2021 Thank you. I cussed that thing for over an hour before I finally somehow got it. Link to comment
