Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 1 minute ago, dirtrider said: Afternoon Cmyers41 You don't have the side stand down do you? Let me clarify, it cranks, but it won't fire and run on the L/H cylinder bloke before. Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 7 minutes ago, dirtrider said: Afternoon Cmyers41 You don't have the side stand down do you? Nope, it's on the center stand. It cranks, but won't fire (on the one cylinder like before). Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 Just now, Cmyers41 said: Nope, it's on the center stand. It cranks, but won't fire (on the one cylinder like before). Afternoon Cmyers41 OK, go back over what you did, is the coil full plugged in, are the injectors fully plugged in. Try holding the twist grip open about 1/8 throttle then try to starting. Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 18 minutes ago, dirtrider said: Afternoon Cmyers41 OK, go back over what you did, is the coil full plugged in, are the injectors fully plugged in. Try holding the twist grip open about 1/8 throttle then try to starting. I'm dumb... Forgot to plug the primary in. Turned right over for me. Still running on the L/J cylinder only Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 Quick video of it idling on one cylinder. 20201018_153450.mp4 Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 1 minute ago, Cmyers41 said: I'm dumb... Forgot to plug the primary in. Turned right over for me. Still running on the L/J cylinder only Afternoon Cmyers41 Well, we are sort of getting nowhere. Can you try to swap the spark plug wires side to side (leave them plugged the same at the coil). Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 6 minutes ago, Cmyers41 said: Quick video of it idling on one cylinder. 20201018_153450.mp4 Afternoon Cmyers41 Is the R/H side front exhaust pipe getting hot at all??? Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 6 minutes ago, dirtrider said: Afternoon Cmyers41 Is the R/H side front exhaust pipe getting hot at all??? Swapped the plug wires side to side, like mentioned above. No change. R/H exhaust is getting hot. Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 3 minutes ago, Cmyers41 said: Swapped the plug wires side to side, like mentioned above. No change. R/H exhaust is getting hot. OK, disconnect the L/H side plug wire, then ground that plug wire (so it doesn't arc internally inside the coil), then see if it will fire off at all on the R/H side. You will probably need to use the choke, or hold the throttle open a bit to get it to stay running. Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 3 minutes ago, dirtrider said: OK, disconnect the L/H side plug wire, then ground that plug wire (so it doesn't arc internally inside the coil), then see if it will fire off at all on the R/H side. Did it with the plug wires still swapped...ran on the R/H cylinder only. Did it after switching the plug wires back over to normal, would not turn over. Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 3 minutes ago, Cmyers41 said: Did it with the plug wires still swapped...ran on the R/H cylinder only. Did it after switching the plug wires back over to normal, would not turn over. That is pointing to a bad plug wire (but it was OK when you measured it way back in the beginning) Try measuring the total secondary resistance. Back to the 200K scale on your meter, then with plug wires back to original position on coil measure resistance from one spark plug wire (spark plug end) to the other side spark plug wire (spark plug end). Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 8 minutes ago, dirtrider said: That is pointing to a bad plug wire (but it was OK when you measured it way back in the beginning) Try measuring the total secondary resistance. Back to the 200K scale on your meter, then with plug wires back to original position on coil measure resistance from one spark plug wire (spark plug end) to the other side spark plug wire (spark plug end). I think I did it right... Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 9 minutes ago, Cmyers41 said: I think I did it right... Afternoon Cmyers41 Yes, you want to see somewhere above 18K & below 25K so you are right there in the ballpark. OK that makes it confusing-- all test good but you still seem to have a dead R/H cylinder with the original plug wire configuration. Personally my Next move would be to run a compression test to validate the R/H cylinder, but you don't have that option. It is kind of pointing to the R/H side of the coil having issues as you can't seem to get a cylinder to run from that side of the coil (with all you have done go back over what you have done to see if you ever got a cylinder to run from the R/H plug wire side of the coil). Probably put a new (good used) coil in the bike then see where you are at. Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 5 minutes ago, dirtrider said: Afternoon Cmyers41 Yes, you want to see somewhere above 18K & below 25K so you are right there in the ballpark. OK that makes it confusing-- all test good but you still seem to have a dead R/H cylinder with the original plug wire configuration. Personally my Next move would be to run a compression test to validate the R/H cylinder, but you don't have that option. It is kind of pointing to the R/H side of the coil having issues as you can't seem to get a cylinder to run from that side of the coil (with all you have done go back over what you have done to see if you ever got a cylinder to run from the R/H plug wire side of the coil). Probably put a new (good used) coil in the bike then see where you are at. I did get the R/H cylinder (dead one) running when I plugged the L/H coil to the R/H cylinder. Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 12 minutes ago, Cmyers41 said: I did get the R/H cylinder (dead one) running when I plugged the L/H coil to the R/H cylinder. Evening Cmyers41 But did you EVER get either side to fire from the R/H side of coil??? Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 Negative, only L/H. I think finding a working coil is my best option. Any suggestions? Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 Just now, Cmyers41 said: Negative, only L/H. I think finding a working coil is my best option. Any suggestions? Evening Cmyers41 Usually E-Bay has a few at reasonable prices. Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 2 minutes ago, AZgman said: https://www.ebay.com/i/392854058895?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=392854058895&targetid=935065067987&device=c&mktype=pla&googleloc=9030097&poi=&campaignid=10833562019&mkgroupid=110337299927&rlsatarget=pla-935065067987&abcId=9300396&merchantid=8290654&gclid=CjwKCAjwz6_8BRBkEiwA3p02VTQvzejH224jz4qG1FxV3HnblyRSfbdmVokAxqfaQm8YtjFswcOC9BoCvOcQAvD_BwE Evening AZgman He doesn't want that one as it isn't the latest design. Link to comment
Cmyers41 Posted October 18, 2020 Author Share Posted October 18, 2020 Thanks for all the help!!!! Once I get a new coil I'll post the results. Coincidentally enough, it is the right side of the coil that is cracked open / damaged. So maybe that's why the right side isn't work? Something (moisture) got up I there and screwed with things? Link to comment
AZgman Posted October 18, 2020 Share Posted October 18, 2020 Got it. How about the one on Amazon? Link to comment
dirtrider Posted October 18, 2020 Share Posted October 18, 2020 8 minutes ago, AZgman said: Got it. How about the one on Amazon? Evening AZgman He needs the 12131341978 black coil. Link to comment
Selden Posted October 19, 2020 Share Posted October 19, 2020 6 hours ago, dirtrider said: Afternoon Cmyers41 You don't have the side stand down do you? Been there, done that. Link to comment
