Blake8098 Posted October 3, 2020 Share Posted October 3, 2020 Is there a way to bypass whatever it is that only allows the bike to start in neutral? Link to comment
dirtrider Posted October 3, 2020 Share Posted October 3, 2020 44 minutes ago, Blake8098 said: Is there a way to bypass whatever it is that only allows the bike to start in neutral? Afternoon Blake8098 Yes, easy way is to just cut the side stand switch wires, then hook them together on the chassis side (this DOES deactivate the entire side stand safety switch though) If you are willing to do some wiring & soldering to install a relay then there is a relay addition that will still allow the side stand switch to kill the engine with trans in gear & side stand down but WILL allow engine to remain running with trans in neutral with side stand down. Link to comment
Blake8098 Posted October 3, 2020 Author Share Posted October 3, 2020 1 hour ago, dirtrider said: Afternoon Blake8098 Yes, easy way is to just cut the side stand switch wires, then hook them together on the chassis side (this DOES deactivate the entire side stand safety switch though) If you are willing to do some wiring & soldering to install a relay then there is a relay addition that will still allow the side stand switch to kill the engine with trans in gear & side stand down but WILL allow engine to remain running with trans in neutral with side stand down. It will already start and run with the side stand down. I’m trying to be able to start the bike in 1st gear. Link to comment
Jim Moore Posted October 3, 2020 Share Posted October 3, 2020 It should start in gear if the sidestand is up and the clutch is in. If it won't you have a bad clutch switch. You can cut the wires going to the clutch witch on the handgrip and wire them together. Link to comment
Blake8098 Posted October 3, 2020 Author Share Posted October 3, 2020 2 hours ago, Jim Moore said: It should start in gear if the sidestand is up and the clutch is in. If it won't you have a bad clutch switch. You can cut the wires going to the clutch witch on the handgrip and wire them together. What else happens if that gets disabled? Link to comment
Michaelr11 Posted October 3, 2020 Share Posted October 3, 2020 1 hour ago, Blake8098 said: What else happens if that gets disabled? You accidentally try to restart the bike in gear and don’t pull in the clutch lever and then you launch yourself somewhere you didn’t intend to. The clutch safety switch is not that difficult to replace. Don’t cut the wires and negate the switch, just fix it. Link to comment
Jim Moore Posted October 4, 2020 Share Posted October 4, 2020 1 hour ago, Blake8098 said: What else happens if that gets disabled? Nothing. The bike thinks the clutch is always in so you have to be aware of that. I prefer cutting the wires to replacing the switch. The switch is unreliable. It's been a problem for 25 years on these bikes. If that switch fails again and you have a neutral switch failure (also not uncommon) at the same time you ain't going nowhere until you do some electrical trickery. Link to comment
Blake8098 Posted October 4, 2020 Author Share Posted October 4, 2020 21 minutes ago, Jim Moore said: Nothing. The bike thinks the clutch is always in so you have to be aware of that. I prefer cutting the wires to replacing the switch. The switch is unreliable. It's been a problem for 25 years on these bikes. If that switch fails again and you have a neutral switch failure (also not uncommon) at the same time you ain't going nowhere until you do some electrical trickery. Is there an article/video on this? I wanna make sure I cut the right thing Link to comment
Jim Moore Posted October 4, 2020 Share Posted October 4, 2020 8 hours ago, Blake8098 said: Is there an article/video on this? I wanna make sure I cut the right thing Not that I know of, but it's pretty obvious. There are two wires in a black sheath. They terminate at the clutch lever housing. Link to comment
dirtrider Posted October 4, 2020 Share Posted October 4, 2020 11 hours ago, Blake8098 said: Is there an article/video on this? I wanna make sure I cut the right thing Morning Blake8098 Smaller of the 2 wire pigtails, clutch safety switch sits is a recess. Link to comment
Blake8098 Posted October 4, 2020 Author Share Posted October 4, 2020 1 hour ago, dirtrider said: Morning Blake8098 Smaller of the 2 wire pigtails, clutch safety switch sits is a recess. Many thanks Link to comment
