venturer434 Posted September 1, 2020 Share Posted September 1, 2020 2011 GS ADV with 130,000 miles. The LH Cam Chain makes a loud noise for 2-3 seconds after a cold start. Any suggestions / recommendations to replace Cam Chain tensioner would be appreciated. Link to comment
dirtrider Posted September 1, 2020 Share Posted September 1, 2020 7 minutes ago, venturer434 said: 2011 GS ADV with 130,000 miles. The LH Cam Chain makes a loud noise for 2-3 seconds after a cold start. Any suggestions / recommendations to replace Cam Chain tensioner would be appreciated. Morning venturer434 The most common approach is to remove the L/H tensioner then see if something is broken or worn in it. But at your mileage I would probably just replace it as precaution. If the start-up chain noise then stops then you got it, if it doesn't then you will have to dig deeper & diagnose the root cause. Link to comment
venturer434 Posted September 1, 2020 Author Share Posted September 1, 2020 12 minutes ago, dirtrider said: Morning venturer434 The most common approach is to remove the L/H tensioner then see if something is broken or worn in it. But at your mileage I would probably just replace it as precaution. If the start-up chain noise then stops then you got it, if it doesn't then you will have to dig deeper & diagnose the root cause. Thanks DR. I am helping a fellow rider diagnose the problem. Link to comment
venturer434 Posted September 16, 2020 Author Share Posted September 16, 2020 Update: LH CAM Chain Tensioner removed and nothing was broken.. the OAL of the uncompressed spring was short by 50 mm when compared to the new replacement kit obtained from EME. Installed everything back and no noise has been observed since with multiple cold starts. Link to comment
dirtrider Posted September 16, 2020 Share Posted September 16, 2020 6 hours ago, venturer434 said: Update: LH CAM Chain Tensioner removed and nothing was broken.. the OAL of the uncompressed spring was short by 50 mm when compared to the new replacement kit obtained from EME. Installed everything back and no noise has been observed since with multiple cold starts. Evening venturer434 50 mm is almost 2 inches, are you sure on that 50mm short? Link to comment
venturer434 Posted September 18, 2020 Author Share Posted September 18, 2020 On 9/16/2020 at 4:24 PM, dirtrider said: Evening venturer434 50 mm is almost 2 inches, are you sure on that 50mm short? Good catch DR, it was actually 5 mm (five mm). Link to comment
