The Rocketman Posted August 27, 2020 Share Posted August 27, 2020 Does the anti-rattle clip that has the arrow facing forward and goes into the top of the rear caliper, go into the top- middle recess of the caliper, or into the rear recess? There's actually a front roundish recess it won't fit in, a middle flatter recess it fits in (which is where I installed it), and a rear roundish recess it seemed to fit it. I just forgot where it went after it fell into my hand. Thanks...... Link to comment
The Rocketman Posted August 27, 2020 Author Share Posted August 27, 2020 Can't tell clearly from this photo, but it sure looks like it goes in the rear opening at the slide pin end. Link to comment
The Rocketman Posted August 27, 2020 Author Share Posted August 27, 2020 Clip moved to rear now. Looks correct. Link to comment
dirtrider Posted August 27, 2020 Share Posted August 27, 2020 7 minutes ago, The Rocketman said: Clip moved to rear now. Looks correct. Evening Rocketman Sounds like you have it figured out. Link to comment
